588,397 active members*
4,825 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Restarting the spindle after spindle stop while in automatic/tape mode on a VMC
    Mar 2007
    156
    While a program is running in automatic (tape) mode, I would like to be able to stop the spindle to clear off the swarf that accumulates on drill bits. However, if I press spindle stop, I can't seem to get the spindle to re-start so I can continue on with the program. Pressing the cycle start button continues with feed movements, but with the spindle still off.
    I have tried switching into MDI mode to do a Sxxx M3, but that doesn't seem to take. I have also tried pressing the clockwise/counterclockwise buttons on the control that can be used to start the spindle in manual mode, but that hasn't worked either.
    Basically I would like to be able to do the equivalent to pressing feed hold and then continuing on again, but instead of just the feed stopping and then re-starting, the spindle would stop and then restart.
    My machine is a Kitamura MyCenter 1 with a Yasnac (very similar to Fanuc) controls if it is relevant.
    Thanks in advance!
    Sep 2006
    607
    The machine I'm working on will pause the program on a M0 command, and resume spindle speed and feed when cycle start is pressed again. So whenever I know I will get chips in the way after a cycle, I will put a M0 in there. If it runs fine without it, I will just remove it after a couple parts when I know everything is good. Perhaps this will work on your machine as well.
  1. spindle stop sometime during runnig in auto mode
    By hemraj in forum DNC Problems and Solutions
    Last Post: 04-22-2012, 05:04 PM
  2. Spindle on in set up mode
    By l u k e in forum Haas Mills
    Last Post: 09-29-2011, 03:14 AM
  3. No spindle when in handle mode
    By jwits in forum Fanuc
    Last Post: 11-18-2010, 01:25 PM
  4. Replies: 3
    Last Post: 09-12-2007, 11:25 PM
  5. Automatic replacement spindle
    By Dag-50 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-31-2005, 10:04 PM
