588,134 active members*
5,448 visitors online*
Page 1 of 3 123
Results 1 to 20 of 47
    Jul 2007
    21
    Lathe turning unwanted taper
    I was trying to turn some 1/2" 6061 aluminum rod down to 12mm on a 7x10 mini lathe, but it's not coming out the way I expected. i have about 1" of the rod in a 3 jaw chuck and 2" of the rod sticking out which I am turning down to 12mm.
    I started turning and measuring the resulting diameter with a micrometer and noticed that the diameter closest to the chuck is narrower then the diameter of the end furthest from the chuck by about 0.001". I'm using the power feed and not touching the compound so the angle of the compound doesn't come into play.
    Anyone have and ideas on what could be causing the problem and how to check for it? I don't have much experience with the lathe so I'm kind of at a loss.
    Thanks!
    Aug 2007
    Is the tool on center and what is your spindle speed?
    Mar 2005
    1673
    Are you doing another/other cut at the same depth to remove the effect of deflection caused by the tool?
    John
    Jul 2005
    12177
    Quote Originally Posted by Hackman View Post
    ... 2" of the rod sticking out which I am turning down to 12mm.....the diameter closest to the chuck is narrower then the diameter of the end furthest from the chuck by about 0.001".....
    0.001" on the diameter is 0.0005" on the radius. Over 2 inches of length on 12mm diameter 0.0005" deflection is to be expected. I would be surprised if you get much better than this even with the sharpest tool you can find. It is possible to reduce the deflection my going to a tool with a very small nose radius and taking the feed very slow to maintain a decent surface finish.
    Jul 2007
    21
    I'm turning at around 750 to 800 RPM, the speed knob is at the 12 o'clock position on the mini-lathe in low gear. I'm using a 5/16" tool bit which is on center.
    I don't think i did. I got kind of discouraged when I figured out the taper was happening and decided to call it quits for the day.
    It is possible to reduce the deflection by going to a tool with a very small nose radius and taking the feed very slow to maintain a decent surface finish.
    I will try a tool with a smaller nose radius. Good to know about the feed setting in the future. Right now I'm already running the slowest gear combination, but I'm trying to CNC this lathe so I can run slower in the future.
    Can i compensate for the deflection by turning the piece twice without changing the cutting tool's position? I'm trying to cut a 2" in length 12mm shaft with -0" + 0.0005" tolerance. (I know, metric + english combination = bad). I'm not sure what the mini lathe is capable of with the stock 3 jaw chuck. Is this pushing it with the mini lathe?
    Is the deflection caused by the tool bending or the workpiece bending? I'm trying to picture in my head what is going on.
    Jul 2005
    12177
    .... Is this pushing it with the mini lathe?
    It is not so much pushing the mini lathe but pushing the workpiece, quite literally .
    The tool has to exert a force on the work in order to cut; it is impossible to do otherwise. If you want to cut something you have to exert a force. The force needed to cause the tool to cut is enough to deflect the small diameter, not very stiff metal, you are cutting especially over the length you are dealing with.
    If it is imperative you have it parallel to within better tha .0005 on the radius turn it between centers. But then of course you may need to align your tailstock center to get this precision.
    A perfectly legimiate alternative is to carefully polish the taper out with some very fine emery paper and delicate fingers.
    Apr 2005
    1778
    Thanks!
    It doesn't sound like deflection to me. It is smaller close to the chuck than out at the end. Wouldn't it be the other way around if it was deflection?
    I would chuck of a piece of drill rod and mount a dial indicator on the tool post and run it along the length by moving the carriage to see if the headstock is aligned to the ways (for a start).
    Alan
    Jul 2005
    12177
    Quote Originally Posted by acondit View Post
    It doesn't sound like deflection to me. It is smaller close to the chuck than out at the end. Wouldn't it be the other way around if it was deflection?....
    Alan
    No, the end deflects away from the tool; in other words the centerline is further away from the cutter so the size is larger further away from the chuck.
    Apr 2005
    1778
    Geof,
    OK, I understand now. I just wasn't thinking clearly.
    Alan
    Jun 2003
    453
    If the lathe has a gap bed make sure the gap peice is seated properly. There may be swarf or a bur on the casting which is preventing the bed from sitting correcly in position, as the saddle of the lathe moves across the section it may be moving away from a level motion resulting in the a taper from the tool rising or lowering as it travels.
    Cheers
    Splint
    Jul 2007
    21
    Thanks Geof. I think I understand what the deflection is now. I think I will try turning between two centers, but first I need to try to align the tailstock. I will do some reading on how to align the tailstock and give it a go.
    Nope, the 7x10 isn't a gap bed lathe so no problem there. Haha, but after reading about gap bed lathes to find out what they were, I've got crazy ideas in my head about bandsawing parts of the 7x10 off to make a gap bed lathe.
    Jul 2005
    12177
    .....I've got crazy ideas in my head about bandsawing parts of the 7x10 off to make a gap bed lathe.
    I hope you are joking. No insult intended but this does qualify as a crazy idea.
    When you cut significant chunks out of something that is cast you are going to relieve stresses in the metal. There is a chance you would finish up with the ways and the surface the head is bolted to no longer co-planar or parallel.
    Gap bed machines have the bed reinforced around the gap and as far as I know the final finishing on the critical surfaces is done with the gap installed so that everything is true.
    Jul 2007
    195
    First try a spring back pass. If you are using a live center in the tailstock, it may be the tailstock is misaligned. You can adjust the tailstock by adjusting the set screws you will find down near the base. Most tailstocks are mounted on a crossways dove tail and the set screws jack it from side to side. just put a piece of stock in and take small cuts while adjusting the tailstock back and forth untill the taper is gone. It's not rocket science!
    Be carefull what you wish for, you might get it.
    Feb 2007
    23
    Your workpiece is extended out of the chuck 4 times your starting diameter and that ratio is growing larger with each turning pass on your way to the desired 12mm diameter (about 15/32"). Use your follow rest or a dead center in the the tailstock if you need accuracy to within .001 of an inch.
    Jim
    May 2005
    1810
    Quote Originally Posted by YouAreA-DUMBASS View Post
    Good God Man ! it's a lathe ! did you go th high school ?
    I attended three high schools in three large cities at opposite ends of the U.S. and not one of them had a lathe. Metalworking is not a common course in public schools. Typing is, though.
    Do any of your posts have any useable information? Do you know the solution to this guys taper issue? Do you have anything of any merit to contribute? Seriously?
    Please find another source of entertainment.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Mar 2005
    1673
    Condescending remarks seem to be the norm in this thread and becoming common place on the zone in general! Its a shame really.
    Jul 2005
    12177
    Quote Originally Posted by Oldmanandhistoy View Post
    That is an exaggeration. There is one post in this thread that is silly which are the ones that consitute condescension? My take on most of the posts here is that they either ask legitimate questions or propose legitimate answers.
    May 2005
    1810
    (response to oldman's post)...and they should be trounced immediately. This forum is for enthusiastic intelligent people - not those who are stuck in puberty trying to figure out what they can get away with from behind their keyboard.
    I usually ignore these folks - just like others typically do, but sometimes I just can't.
    Sorry to detract from the thread, guys. Let's move on.
    Scott
    Sep 2006
    340
    What is really going on!!
    Is 1) the runout on the chuck bearings. or 2) the bed could be a little warped...
    A live center is a MUST, your TAIL stock could be OFFSET too... I am assuming that it is not with the above information number 1 and 2..
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    Jul 2005
    12177
    Hackman; To put it mildly you are being given conflicting opinions. To determine whether it is workpiece deflection or machine inaccuracy do an experiment: Get a piece of 2" diameter 6061 and turn off a similar amount. i.e., take off about 0.03". The 2" diameter will definitely not deflect measurably over a length of 2 inches and if you get taper this time then you know it is due to the machine.
Page 1 of 3 123
  1. lathe turning
    By klugster in forum MetalWork Discussion
    Last Post: 11-01-2012, 05:25 AM
  2. unwanted circles
    By Prboz in forum Mach Mill
    Last Post: 03-23-2009, 04:24 PM
  3. which lathe for ballscrew turning
    By margni74 in forum Benchtop Machines
    Last Post: 08-30-2007, 02:54 PM
  4. cnc lathe taper problem
    By trh400 in forum MetalWork Discussion
    Last Post: 08-11-2007, 04:24 PM
  5. unwanted circles along curve
    By Pbrew1 in forum G-Code Programing
    Last Post: 07-29-2006, 10:23 PM
