588,500 active members*
4,950 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Using tool probe to get bore size.
    Aug 2009
    Is there a way to measure the bore that has just been machined.
    The bore is probed before it is machined to finish size of 22mm. Is it possible to probe the bore once again in order to get an accurate measurement with out removing from the fixture.haas cnc mill v2
    Jul 2008
    47
    #188 in both 9814 and 9823 bore/ boss cycles will display the diameter immediately following the measuring cycle. I usually save it to another user variable as it will be erased when you start another measuring cycle. It's up to you how much you want to trust that measurement. I usually see accuracy of about +/- a few tenths from what I measure. Depends on your tolerance really. I get a lot of tight tolerance bores I locate to and monitor the bore size sometimes.
    Greg
    Jun 2008
    62
    Run the Probe Bore Cycle again, but Dont enter a work offset, just the diameter, just in case the bore isnt at X0Y0.
    After the cycle has ran,
    Press 'Current Commands'
    page down 3 times
    enter '188'
    press down arrow
    there is your bore size
    HTH:wee:
  1. pulley bore size question
    By satguy in forum DIY CNC Router Table Machines
    Last Post: 06-16-2009, 06:16 AM
  2. Tool Probe
    By Astrocncdept in forum HURCO
    Last Post: 04-03-2009, 02:19 AM
  3. Replies: 6
    Last Post: 06-12-2008, 07:24 AM
  4. Tool Probe
    By b.locke in forum HURCO
    Last Post: 02-21-2008, 04:14 AM
  5. Tool Probe Arm
    By phoodieman in forum Daewoo/Doosan
    Last Post: 11-01-2006, 10:32 PM
