Originally Posted by
PaulRowntree
While we are exchanging ideas on this topic, what is the largest size of CNC that folks have built as a separate cart & machine? How well does this work for large machines?
I am thinking of a 4'x6' machine, and would like to build the machine of steel, perhaps a separate wood cart like the Stinger photos and an acoustic shell like Don's. Is this realistic? Aside from the trouble of getting the machine onto the tabletop that is ....
Cheers!
If the steel framework is stiff enough, you can lift it from one corner and the adjacent corner will lift at the same time without bending. The cart rolling on a non-flat floor will cause very little twist in the framework. If the machine is too heavy for you and three friends to lift onto the table, jack and block the machine up high enough to roll the cart under the machine.
There are many ways to safely get the machine onto the cart. Just be sure that the cart can safely handle the weight while pushing the cart around the shop. A 4' x 6' machine shouldn't be a real problem.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
