588,245 active members*
4,286 visitors online*
Results 1 to 10 of 10
    Jan 2007
    723
    Calculating steps per inch!
    When I first set up my converted CMM router I had some weird screws with an unknown pitch. I had to use Mach3's built in calculator to find the steps per inch value. That worked fine for the work I was doing on it but now I have the chance to make the numbers absolute.
    I have replaced the unknown lead-screws with 10mm pitched ballscrews. I have also upgraded the motors and controller to a g540 and 200 step per inch motors. My big question is..... Mathematically, how many steps per inch do I need?
    10mm = 0.39370079 inches
    200 steps per inch motor @ 10 microsteps = 2000 steps per rotation?
    2000steps = 0.39370079 inches
    5080steps = 1 inch
    Is my math correct?
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    yep.
    Nov 2010
    I am curious how you are getting 10 micro-steps?
    You would need 5-coil stages to get that from the controllers I know of.
    Normally, there are 4-coil stages, and thus four wires, two paired sets (A,B), yielding the 4-coil stages. (+ -, + -) (- +, + -) (- +, - +) (+ -, - +) repeat.
    That is single-step operation or 1x.
    Then there is half-step, which uses 1/2 current between each phase-switch.
    1/4, 1/8, 1/16... etc.
    I wasn't aware there was a 1/10th step controller. (Would that be the "metric" of controllers? Sounds interesting.)
    Does it let you select individual steps? 10/10, 9/10, 8/10... etc...
    "There are no mistakes in DIY, only oversights that need adjustments."
    "I don't care, I don't follow standards"
    All Geckos use 10 microsteps. Most are fixed, but they do have models with step multipliers if required.
    Nov 2009
    724
    I believe the g540 is a 10 microstep driver
    G540 4-Axis Motor Control
    JTCUSTOMS
    Mar 2009
    624
    In my experience there are more that do 10x times than dont..
    Pplug: I would still use the set steps per feature in Mach, If used with an accurate measureing system it will be more accurate than just setting the steps per @2000 because it helps account for any inaccurecy's in the screws/motors etc and counts the actual steps taken to move a set distance.
    Dec 2010
    probably steps per problem
    Hello.
    I have a 4 axis cnc mill. I have a problem and manufacturer said that it is problem with steps per but I am not shure if that is the case.
    When I mill ring( I mill jewelery) The tools starts at the botom of it and than goes around and finishes where it started. but not exactly where it startdds it is a mistake that is big for jewelery industry. about 0.25mm. the toolpath lenght is abou 4 meters. that happens mostly in y axis direction (longest toolpath is in y) and a little bit in z axis direction.
    Should I change steps per or is there any other problem.
    I would be glad if anyone helped.
    Hope I write it under right category.
    Thank you, Matic
    Mar 2009
    624
    Quote Originally Posted by Tmau View Post
    Hello.
    Thank you, Matic
    Hello Matic,
    I would be pleased to help but really you need to create your own thread asking this question.! It will take meny posts to help resolve this issue and it's not fair to Pplug for us to hi jack his thread.
    Make a thread then we'll look at it for you.
    Apr 2004
    5758
    That sounds like backlash
    Most rotary tables have some. You run into it when you change directions. Try running the rotary axis a revolution or two in the direction it turns the part, then zero it without changing direction.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Jan 2007
    723
    It all came together last night! I put in 5080 into the steps per inch and the darn thing works! I used my digital calipers to measure the travel and it is spot on! I'm sure I could get more accurate with a dial but for a quick spot check it worked!
    Thank you all for validating my dusty 15 year old high school math skillz!
  1. Need help calculating steps per unit (rack and pinion)
    By idtkid in forum Mach Software (ArtSoft software)
    Last Post: 04-27-2009, 07:06 PM
  2. steps per inch
    By Chris Tucker in forum Linear and Rotary Motion
    Last Post: 08-14-2008, 01:50 PM
  3. Calculating Steps with Xylotex Board
    By cxixer in forum Machines running Mach Software
    Last Post: 05-19-2008, 02:10 PM
  4. Need help on calculating steps
    By rustamd in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2007, 01:08 PM
  5. Calculating steps per revolution
    By watsonstudios in forum Mach Software (ArtSoft software)
    Last Post: 06-25-2007, 07:22 PM
