Hi All,
OK… I think I know the answer to this… but I want to make sure.
I am working on automating a saw for my shop, and I want to use a Gecko with a servo to feed the stock. If I’m using a PIC or a stamp to run the Gecko… All I need to do is hold the “Direction pin” either high or low while pulsing (bit high to low) the “Step pin” to drive the servo…Right?
Then… does anyone know if the logic level (bit high or low) from a Stamp or a PIC, IO is good enough to drive a Gecko?
