![Quote](images/misc/quote_icon.png)
Originally Posted by
renatopub
My board is a bit different than yours. I have LEDs that show when pulses are coming from the LPT. Do you have that?
I think the first thing to check is whether the LPT is sending the pulses or not...
Your motor connections look good, as the black and white cables are for use in unipolar configuration only, and that is not the case for your board. So you are good using the sequence color sequence Green-W/Green- Red-W/Rred.
So I would first make sure the direction and pulse lines are doing what they should.
