The PMDX-125 MultiMode Breakout Board from PMDX is
now in volume production and available from stock.
This new breakout board continues the evolution of our
product line by adding advanced features such as:
1) Support for the SmoothStepper as a daughter board
2) Expanded modes to provide up to 4 additional inputs
and 4 additional outputs using a single parallel port
3) Ability to interface with 24 volt inputs like PLCs
4) Support for up to 6 axes using a SmoothStepper or dual
parallel ports
5) Interface to directly support Geckodrive servo products
with ERR/RST pin allows fault sensing AND reset under
computer control
6) One on-board relay rated for 30 amperes for direct
switching of power for small and medium size single
phase spindle motors
7) On-board 115/230 volt AC input mains power supply that
is adequate for powering common accessories including
the SmoothStepper, PMDX spindle controllers, and PMDX
accessory I/O boards
8) Pulse stretching circuit to allow use of encoders with
narrow index pulses to be used for spindle pickup
9) Advanced "charge pump/watchdog" function is enhanced
to avoid "teasing" by the Windows boot sequence
10) Built in test can run motors without a host computer to
allow testing wiring and adjusting stepper motor drivers
PMDX will be displaying the new PMDX-125 and many of
our other products at the Cabin Fever Expo this coming
weekend, Saturday and Sunday the 16th & 17th of
January 2010.
Additional information about the PMDX-125 can be seen at:
http://www.pmdx.com/PMDX-125
Looking forward to seeing many of you at Cabin Fever.
Regards,
Steve Stallings
www.PMDX.com
