588,397 active members*
4,447 visitors online*
    Aug 2007
    4
    overhaul spindle tool clamp
    Hello, this is my first post.
    I would like to get advise on the prociedure of overhauling the spindle tool clamp/unclamp unit on a Matsuura 510VF machining center. According to the owners's manual, I should replace the "drawing bolt" and the "countersunk spring", (I think they mean springs).
    thank you
    May 2003
    41
    Spindle Clamping Overhaul
    Dear Sanate,
    I have not worked on Matsuura, but a Milling spindle does not vary much from machine to machine. Following are my points:
    1. Why does the Clamping System Need Overhaul?
    2. Please get detailed spindle drawing, incl. of clamping system from the MTB (the machine tool builder).
    3. Normally, cleaning the collet of the clamping system is enough. This cleaning can be done by spraying solvants like diesel or WD40.
    You may spray some low viscocity oil (hydraulic Oil) on the collet after cleaning.
    4. The Clamping system of HSK tapers need more overhauling than BT or ISO spindles.
    5. In case you have to dismantle the clamping system, be extremely careful, as the extremely high spring tension can cause personal injury. Therefore, please ask for correct procedure from the MTB.
    smabhyan
    Aug 2007
    4
    Thank you for your attempt to resolve my question smabhyan. You were the only one to reply to my question, actually I was quite surprised that this question was not asked before. Fortunately I have resolved this issue.
  1. tri-power overhaul
    By morbius in forum Shopmaster/Shoptask
    Last Post: 11-26-2007, 02:59 AM
  2. Problem on PUMA8 of spindle speed clamp G92
    By Ashu in forum Daewoo/Doosan
    Last Post: 11-04-2007, 09:17 PM
  3. VFD Conversion/Overhaul ?
    By Verboten in forum Phase Converters
    Last Post: 04-21-2007, 04:05 AM
  4. Spindle Tool Clamp/Unclamp Alarm
    By Q12321 in forum DNC Problems and Solutions
    Last Post: 10-10-2006, 09:24 PM
  5. Hitachi spindle clamp pressure
    By pieface in forum Vertical Mill, Lathe Project Log
    Last Post: 02-10-2006, 03:27 PM
