Hi JerryBurks, I don't have an opinion on the tapered bearings but I would suggest quantifying the drag.
If you put a small lever on the coupling (even an allen key in the grubscrew) then measure the force needed to rotate the screw at that distance and calc oz inches.
Then you could do the test again with the bearings removed and the oz inches would be for the motor detent torque and the leadnut drag.
The difference between the two measured torques would be the drag solely from the tapered bearings.
![Smile](images/smilies/smile.png)
