586,036 active members*
3,747 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Step/direction to analogue converter
Results 1 to 9 of 9
    Sep 2016
    31
    Having been put right on the UHU servo controller, I need a cheap-ish means of converting step/dir pulses to +/-10 to control some analogue AC servo drives.
    Any suggestions?
    Thanks David
    Aug 2015
    142
    Re: Step/direction to analogue converter
    Search for
    YAPSC:10V
    Feb 2007
    966
    Step2Linear
    ViperServo
    Sep 2016
    31
    Thanks for the suggestions. The YAPSC seems like a good solution.
    Jul 2003
    1754
    The viper2linear looks cool. But..
    if you have a 3 axis machine - you are going to spend about $270.
    With linuxcnc and mesa hardware - you get true closed loop 6 axis analog control plus 48 i/o and expandable. $280 (comes in ethernet, pci or pcie)
    sam
    Sep 2016
    31
    Quote Originally Posted by samco View Post
    sam
    Thanks Sam. Yes, the Viper is not economical for the problem I'm trying to solve - it would be better to buy used step/dir drivers. I'm seriously considering the LCNC/Mesa route, but compared to Mach3, LCNC seems like learning Mandarin compared to learning Spanish! One advantage of LCNC is that the Mesa boards are easily available in Europe.
    It looks like the YAPSC project has extinguished itself, with no boards currently being made - shame.
    Feb 2007
    966
    Triplet
    No problem. if you think $89 per axis on a CNC machine s "not economical " to save your servodrive ..omg
    ( btw..I make about $40 profit on one on those.. not counting the couple hours of work to build and test it and the 1000's of hours to develop it and write the code, and tuning program. )
    good luck finding a solution, ( but please don't order one from me. )
    Larry K
    Jul 2003
    1754
    Wow
    Sep 2016
    31
    Hi Larry
    I understand the difficulty of making a living at a bench too well! If I was trying to run servos that were integral to the machine I'd very much agree $89 per axis is nothing. However, my situation is that I've acquired some servo drives very cheaply without realising they are analogue, so it's only worth bothering with them if I can do it on the cheap - by the time your converters end get posted to the UK and then get clobbered for taxes etc I can get replacement drives for not much more and sell off the analogue ones.
    Best regards
    David
    Quote Originally Posted by Larken View Post
    Triplet
    Larry K
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Replies: 4
    Last Post: 09-10-2013, 04:52 AM
  3. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  4. step/direction to +/- 10v (analog)converter
    By krummigudna in forum Mach Software (ArtSoft software)
    Last Post: 10-14-2009, 03:41 PM
  5. PWM&direction into voltage converter
    By visky in forum Want To Buy...Need help!
    Last Post: 04-05-2009, 05:47 PM
