Hey guys, first post as a Tormach owner!
I'm using a 2D contour operation to mill some slots in 360 alloy brass. Now that I have all of my programming bugs worked out, I've been playing with different end mills and such to get the most speed with the best finish possible.
I was using a .5", 2 flute carbide, 5000RPM's @ 46IPM. .1"DOC and the width of cut in the program is .5". Although that's kind of deceiving, based on the round tube. This left a nice shiny finish, but the burrs were horrendous no matter how I adjusted the F&S.
I picked up a 4 flute carbide and ran it at the same parameters, and it was quiet with almost no burrs. The finish was a little less than desired, obviously because the 4 flute needs to feed faster, but close to what i'm looking for. Using G-Wizard, the recommended F&S is 5000RPM, 90IPM. I'm a little nervous to push such a long cutter (4" OA, 2.5"LOC) that fast inside of the fixture.
With all of the experience on here, I was hoping for a little more advice to help me fine tune things.
Al
