588,344 active members*
5,307 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > CNC Mill Electric Motor. What should I use?
Results 1 to 6 of 6
    Jun 2012
    I want to build a CNC mill that can carve and engrave wood or plexiglass, but I am not sure what motor to use. I was thinking a Replacement Wood Router motor because it has High speed and High torque and is made for cutting through wood, but they use (I believe) 120 volts, I also found a 36 Volt motor (can be seen here) but is $300.I am also wondering what should I look for when trying to find a motor? I would appreciate any help and/or suggestions anyone might have.
    Thanks.
    Jun 2012
    91
    Why is 120V a problem?
    Mine is 240V (european standard).
    You power your spindle/router off the mains, not off the power supply used to powering the stepper motors.
    Jun 2012
    Can I hear what people are using on their Mills?
    Jun 2012
    91
    I dunno - unless they're really loud, you probably have to stand quite near.
    I am less interested in hearing them than I am in knowing what make and model they have.
    Sep 2005
    19
    Quote Originally Posted by Zootalaws View Post
    That's funny
    Jun 2012
    91
    I was feeling mischevious
  1. Electric Motor Recycling
    By cjjonesarmory in forum Maintenance DIY Discussion
    Last Post: 08-07-2019, 08:40 PM
  2. Most efficient electric motor?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 11-17-2014, 05:19 AM
  3. Electric Motor Question
    By daedalus0x1a4 in forum CNC Machine Related Electronics
    Last Post: 11-07-2011, 05:45 PM
  4. Homemade 3-phase electric motor
    By kadora in forum CNC Machine Related Electronics
    Last Post: 10-21-2008, 07:53 PM
