http://www.arizonavortex.comThe Arizona Vortex CNC Cooler uses a Vortex Tube to convert compressed air into two streams-one hot and one cold. The cold air is discharged into your electrical enclosure. The air is filtered before it is cooled so that only clean dry air is introduced to the sensitive controls. There are no moving parts so you can install the CNC Cooler and forget about heat related shut-downs. Relief valves and seals are built into the CNC Cooler to enable the unit to maintain the sealed nature of NEMA boxes. Also, since all enclosures are not airtight, the CNC Cooler creates positive pressure within the enclosure to seal out any debris.
