588,585 active members*
14,383 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Baldor drive doesnt power up (Axis faults on cold start)
Results 1 to 8 of 8
    Apr 2005
    1194
    I am not getting any indication that the baldor drive is powering up on one of these mills 1993 3016 88hs and when I cold start it gives me a amplifier fault and this can be one of many of the 3 axis. I dont see any popped fuses, no breakers have been popped and all three cards have blinking red lights.
    Apr 2005
    1194
    Their are 4 cards on the bottom with blinking lights and none of the three in the middle have any lights on...I believe it may be a power issue.
    Apr 2005
    1194
    Error reads
    "Spindle driver fault
    Position limit"
    No fuses are blown and no popped breakers..
    It appears that the baldor drive is not recieving power. Nothing comes up on the screen on the drive!
    Help!
    Apr 2005
    1194
    Could I have a Voltage problem? All three legs tested out at 213V so I had the machines wired to 210...should I have gone to 230?
    Apr 2005
    1194
    Now two machines stuck in E-stop mode
    Apr 2005
    1194
    So we are up against K18 or K20 and we jumped 26 to 30 and the other jump to test for 4th axis plug or Estop button error and didnt get anything. Anyone else have this issue before? Seems like we have alot of silly problems with our little fadals (Stupid simple I am sure)
    900
    Have you tried running the spindle from the LOCAL setting on the Baldor? If it runs there then the issue is in the computer side not the drive side.
    Next, at the spindle drive unit check pins 4 & 6 on the 6 pin Molex connector. This is the command signal from the Spindle controller card in slot 14 of the card cage. At max RPM the signal voltage would be 10 Volts.
    Neal
    Apr 2005
    1194
    I found that our Y axis card was bad after swapping
  1. Baldor Vector Drive Problems
    By ferroma in forum Fadal
    Last Post: 09-04-2018, 06:50 AM
  2. New Spindle drive (baldor)
    By Lonewolf32 in forum Fadal
    Last Post: 07-13-2007, 06:32 PM
  3. Baldor Servos And Drive
    By Cycle Start in forum Servo Motors / Drives
    Last Post: 05-29-2007, 01:28 PM
  4. VFD drive Faults on series I cnc Bridgeport
    By colin1544 in forum Bridgeport / Hardinge Mills
    Last Post: 09-22-2006, 11:36 PM
  5. 904-1 cold start
    By yeepman2 in forum Fadal
    Last Post: 05-02-2006, 02:58 PM
