587,998 active members*
1,980 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Need help with g-code/CAD drawings for full-size 1911 grips
    Nov 2011
    I'm new here and this is my first post.
    I've been looking looking online for the g-code to make 1911 grips for a small little home project. But every time I stumble upon a file I can't seem to open it right. If anyone has a CAD drawing of full size 1911 grips, I could use those too. I found two .jpegs of it in this thread \\//
    http://www.cnczone.com/forums/rfq_re...de_needed.html
    but they are a bit blurry... not sure where to find the pdf version.
    If someone has the g-code or could provide me with it, it would be much appreciated. Been working on my own for a bit and I think it's time to ask for help, still very new to this.
    Nov 2011
    Models and g-code for 1911 grips
    Follow link to a zip file from solidworks. The part models got renamed and the camworks stuff is screwey, sorry.
    http://dl.dropbox.com/u/33174015/1911Grips.zip
    I work with carbon fiber and had some scrap to make these grips.
    You'll need to edit the code to eliminate the ball milling of "Swigart".
    Also, There is code for making the fixture.
    I put the carbon fiber plate on with outside clamps and milled the thru holes and inside C'bores first, then flipped the whole plate over and lined up on the thru holes, clamped, C'Bored, installed screws. Screws must recess low enough to clear ball milling. Ball milled first, then finished the profile. Grips are seperated only at the end when profiled.
    Setup.doc has tool list.
    files ending in .txt are the G-Code. There are M00's and Comments in the .txt files.
    Aug 2010
    107
    Do you have cad/cam software? I have a cad files of 1911 handgrips, frame, and slide.
    Nov 2014
    6
    Re: Models and g-code for 1911 grips
    Quote Originally Posted by hairyolds2000 View Post
    Dropbox - 404
    Link not working, where can I find it?
    Saludos,
    Carlos
    Home
  1. 1911 Gun Grips
    By jaxncurtis in forum Gunsmithing
    Last Post: 03-19-2015, 04:26 PM
  2. Full size templates ?
    By windwalkerjim in forum Joes CNC Model 2006
    Last Post: 04-12-2009, 02:04 AM
  3. Benchtop vs Full Size?
    By ATV in forum Benchtop Machines
    Last Post: 02-17-2008, 02:20 AM
  4. Fabrication Drawings With Full Detail
    By weaston in forum Mechanical Calculations/Engineering Design
    Last Post: 08-13-2007, 12:43 PM
  5. Pistol grips 1911 Kimber
    By Revtech in forum Uncategorised CAM Discussion
    Last Post: 02-01-2007, 03:29 AM
