588,268 active members*
11,768 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Using Work Offsets (G54-G59)
    Mar 2007
    215
    Can someone tell me how to how to utilize work offsets in Mastercam x4. I'm assuming its something simple I'm overlooking... Thanks
    Feb 2006
    57
    you have to go into the configuration and add the view manager button to the toolbar. You can create new veiws and use them to create new offsets. You have to make sure you have the view plane and the construction plane set the same for example top and top. You can change them in the planes tab in the toolpath dialogue box for the toolpath your trying to give a different work offset.
    Mar 2007
    215
    Thanks for the reply. I copied the views and set the offsets but when I posted the program it didn't post the different work offsets
    Mar 2007
    215
    Nevermind, figured it out!
  1. Replies: 12
    Last Post: 04-05-2019, 10:21 PM
  2. work offsets
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2009, 05:39 AM
  3. Work Offsets
    By RMT in forum Mach Mill
    Last Post: 12-14-2008, 04:49 PM
  4. work offsets
    By 5axisdan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2005, 04:17 PM
  5. Work Offsets
    By new2cnc in forum Mastercam
    Last Post: 04-30-2005, 04:04 PM
