Hi. I need to make a very simple part, and I'm frustrated that I can't do it (I need to make a wedge shaped exhaust flange spacer, to help angle a downpipe slightly), so I have decided having a milling machine would be great, and even cooler would be if it was CNC-ized.
Here is what I am going to buy, does this look OK to start with? Any advice?
Weiss WMD25 milling machine, from Hugh at Amadeal UK as the AMA25LV, expected delivery in about a month.
Geckodrive G540 controller thingy. I'm right in thinking that this thing interfaces directly with the motors, so no other circuitry stuff is needed, right?
Then I just need to pick three motors (for now), some ballscrews although at first I intend to have a go with just using the leadscrews to see if it works at all, and a power supply?
Am I anywhere near doing things right?
cheers,
Carl
