Re: How do I determine how big of a power supply to use with my servo motors?
There is apparently two Mosfets on the board Q2 Q3 they have G.D.S. Gate-Drain-Source.which is the termination labels used for Mosfets.
Not sure why you would need any sophistication in a servo supply, normally all that is needed is a large linear transformer and bridge and caps.?
What is the Kva of your present transformer?
Al.
Albert E.
