587,656 active members*
7,703 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Z Axis auto zero plate wiring on usb motion controller
Hybrid View
    Nov 2006
    29
    I just got a JCut 90150B machine and I'm setting it up. I have a question on how to wire a Z Axis auto zero plate to a Mach3 AKZ250 USB Motion Card using the internal 5v power supply. The manual only shows how to wire it externally. Would it be possible to wire Z Axis auto zero plate as shown in the image? There are 2 sources for 5v and grnd on the board, Ive traced them both on the schematic but would only use one.
    Jun 2007
    16
    You'll short +5 out from the board to ground!
    You could try taking the 5v out through the 330Ω out to the touch sensor. That would limit the current when the spindle and touch plate short.
    But what's a couple of batteries worth? If something doesn't work right it's easier to get support when your wiring matches the manual.
    Oct 2017
    Re: Z Axis auto zero plate wiring on usb motion controller
    Quote Originally Posted by phongshader View Post
    Hi, how did you wire it in the end please? I thought I'd be able to just take the +5v and connect it to my sensor wire that's connected to pin 15. I have it working with a battery and a suitable resistor as per their diagram but I'd prefer an internal 5v.
    Des Owen
    Nov 2006
    29
    Quote Originally Posted by DesOwen View Post
    Des Owen
    I just used a battery until I upgraded to an ESS smooth stepper controller.
  1. Replies: 0
    Last Post: 09-17-2013, 05:38 PM
  2. Low cost 6 axis USB motion controller
    By Xerxes in forum CNC Machine Related Electronics
    Last Post: 07-18-2012, 04:26 PM
  3. e-stop wiring for a JMAR Precision motion controller?
    By josh591 in forum Servo Motors / Drives
    Last Post: 04-17-2009, 07:06 PM
  4. 3-4 axis motion controller
    By grebator in forum Stepper Motors / Drives
    Last Post: 04-19-2007, 09:15 PM
  5. CNC Auto-Motion 5th Axis
    By ninthmp in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2006, 12:42 AM
