588,408 active members*
5,282 visitors online*
Results 1 to 15 of 15
    Feb 2006
    8
    Angry Yasnac i80 error 102
    hi. looking for info for error code 102 on yasnac i80 on kitamura mycenter4, error acures while changing rpm's in g code, ex:go1 xxxx;s1000; (chair)
    Initial rpm from home is fine S800 M03,
    G01 XXX;
    YYY;
    S1000;
    XXX;
    S0800; (ERROR 102)
    Is this a format or parameter problem? tried using M03, didn't help!
    Mar 2006
    1625
    look in you manual for what that code means
    Feb 2006
    8
    Did that, means misuse of code. I have changed rpm's on many controls, never had a problem. wondering if a parameter for rpm change is the problem
    Mar 2006
    1625
    yasnak I-80 is a funny controller are you running a Matsuura mc you may may to put a m3 after speed change with the line of code your telling it to change speed and not to turn on
    Feb 2006
    8
    tried sxxx m3; didn't help! This yasnac i80 is on a Kitamura MY-4
    Mar 2006
    1625
    put a m5 before speed change you may be at a gear change I never ran that machine so this is only a guess
    Feb 2006
    8
    Tried m5;
    s1000 m3; didn't work
    Mar 2006
    1625
    you got me?
    Feb 2006
    8
    i have attached the txt file, maybe i'm missing something
    Attached Files Attached Files
    Mar 2006
    1625
    take the m03 out below error code(Y.1383 M03 F7.5) the controller is reading a head you have a speed chagne to 1500 rpms without m3 and it works
    Mar 2006
    1625
    error code happen after the line that they trip on Yasnak I-80 reads ahaed like 100 lines or something like that so you could have a problem anywhere after line that trip alarm also on line with G28 I like to put a X move in to have part in center of door for changing
    Feb 2006
    8
    I agree the M03, needs to be removed! But this code was edited, previously read G01 X44.07 F14.
    Y0 S800 m03
    Z-.3 F20.
    Y.1383 F7.5. (Ok what’s wrong with this picture..............oh one 2 many....) (chair)
    X2.6969
    Well maybe this yellow background makes this obvious?
    I'll have to look at the control come Monday to see if this is the case.
    Thanks for getting me to look at this again!
    Ps: I didn't mention it before, but while trying to isolate this problem I ran the control in single block, the control only reads 1 line & buffers the next I believe.
    And normally I move the x center, but this is for part loading convenience only.
    Didn’t bother this time, 1 pc job
    Mar 2006
    1625
    In single block controller will only read one line on full auto it look ahead.Also that what you got to love about code it's always in front on your nose and seems to hide
    Mar 2006
    167
    error says misuse of "-" or "."
    line after your error line says F7.5. should be F7.5
    regards, Oz
    Mar 2006
    1625
    Quote Originally Posted by Ozemale6t9
    regards, Oz
    you got good eyesight and saw what was hiding in front of our noses good for you OZ
