587,642 active members*
3,859 visitors online*
    wklaserliu Guest
    cheaper fiber cutitng machine for steel
    Working size: (L*W)2500mm×1300mm
    Laser tube: 200W Raycus fiber laser tube
    X,Y,Z axis range: 2525mm/1325mm/100mm
    The thickness of the material: 0.1-2mm(Depending on the material)
    Maximum cutting thickness: 2mm
    Position accuracy: 0.03mm
    Maximum moving speed: 20m/min
    Net weight: 1000kg
    Operating temperature: 0℃-40℃
    Control system: MPC6595
    Workbench maximum load: 100kg
    Drive type of X, Y axis: imported servo drive( Panasonic, Japan)
    Moving mode: imported TBI rolling ball screw
    Machine size(L*W*H): 3800*1850*1300mm
    our fiber cutting machine LF1325L 300w is good choice fro you .
    Attachment 326976Attachment 326978Attachment 326980Click image for larger version.
Name:	other agents phoots IMG_2669.jpg
    Quiven form gweike laser
    [email protected]
    skype;wkquiven
    May 2015
    6
    Hi everybody,
    Laserprona is one of the leading supplier for providing the Laser engraver machine for cutting steel at very affordable prices.The engineers prefer to use the machines for cutting steel and other materials easily in many industries.The engraving machine uses the laser technology to accurately engrave any type of materials on different kinds of surfaces. It is perfect and easy for cutting in the laser process. The industry of laser engraving enjoys a widespread existences since every tiny glass in a small shop to big malls, specialty stores, wood panels to large warehouse packages, utilizes the laser marking option for convenient and cost effective marking.
    Best regards
    Alex Hennell
  1. 1000w IPF fiber cutitng machine cut 10mm carbon steel ?!
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-30-2016, 07:31 AM
  2. steel, aluminium,galvanized sheet metal fiber cutitng machine
    Last Post: 01-15-2016, 04:26 AM
  3. 8to 10mm steel fiber cutting machine
    Last Post: 12-19-2015, 09:00 AM
  4. 1000w fiber laser cutting machine cut 6mm steel
    By Lasersolution in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-16-2015, 12:09 PM
