588,633 active members*
5,806 visitors online*
Page 1 of 3 123
Results 1 to 20 of 47
    Aug 2003
    75
    Home Built Tubing Bender
    Has anyone found and good plans on the web anywhere for something along these lines ?
    I've got most of the hardware to build a ram style machine with two guide rollers on either side of a ram arm with a die on it.
    I've got the steel stock, and hydraulic pump but need a cylinder and gang valve to construct one myself.
    If no plans that anyone knows of ...... then can someone suggest some online links to some surplus hydraulics equipment ?
    thanks all,
    art
    Oct 2003
    927
    Apr 2003
    1873
    CCM,
    Here is a link that may offer some ideas, no plans but lots of pictures and some advice.
    Ken
    http://www.blindchickenracing.com/to...bingbender.htm
    Sep 2003
    1113
    ccm -
    if those bits (cylinder and gang valve) run you more than 70 bucks you can get a charlie-chan (chinese built - no offense intended!) thru Homier. Saw the whole set up today at the truck sale - looks usefull and had several sets of formers too - but for pipe bending. It was a 12 ton ram.
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Feb 2004
    361
    depends on what you want to bend, pipe [thick wall] can be done on almost any type of bender..but tubing [thin wall, needs a 'mandrel' or similar style of bender, I've used a HOSSFELD, worked pretty good, a muffler shop style of machine 'squashes' the pipe down a bit at the bend points.. small stuff can be bent with an electrician style foot bender [one size, one die..]
    enjoy..
    Nov 2003
    244
    Harbor Freight $89.00 pipe or tubung bender, Bends 6 different diameter pipes from 1/2" to 2". Bending bars can be adjusted to distances of 8-1/2", 11-1/4", 12", 16-3/4", 19-1/2" and 22-1/4". 2" diameter 12 ton jack. Jack capacities: 13-1/4" minimum; 22-3/4" maximum; 9-1/2" stroke. Precision cast dies.
    http://www.harborfreight.com/cpi/cta...emnumber=32888
    Tom
    ...He who makes no mistakes makes nothing! ...
    Tom
    May 2004
    22
    Try Princess Auto, they should have some stuff there.
    Nov 2003
    37
    The HF bender is good for heavy "pipe", but for actual tube it will kink the heck out of it. You will have to buy a "tube" bender for tube, or if you make your own at the very least buy some tube dies, which are pretty pricey themselves.
    Jul 2003
    71
    try minichopperplans dot com as they have two sets of plans that you can buy for twenty bucks they will bend .5" to 1.5" tubing. The only tricky thing is the die which can be machined easily.
    I am currently making one out of scrap metal and so far has only cost me $10 for a 4 ton jack.
    Give me a e-mail if you have any other questions about the plans.
    Nov 2003
    The HF bender is a rigid conduit/schedule 40 pipe bender. It is very accurate for rigid electrical conduit. It is slightly less accurate for schedule 40 aluminum. It is worthless for thin walled tubing. There are shoe-type benders that will work with standard electrical tubing, which is a great resource. There is also a hand held "pipe hickey" which pros use to bend rigid electrical conduit, but it takes a while to learn to master it.
    Jul 2004
    55
    http://198.247.193.8/wwwroot/greenlee/bending.pdf
    Here's what most all electricians use to bend conduit over 1" dia. There are some hydraulic ones like you describe further down. You'll need a different shoe for every pipe diameter. If it's wrong, the pipe will kink or flatten out.
    If it ain't broke... fix it 'til it is.
    Apr 2003
    312
    Home built tubing bender...
    How about making a roller bender??? I remembered a long while back Mother Earth News had one in their mag... I found it in the archives...
    http://www.motherearthnews.com/arc/1857/
    The size can be modified for the particular need...
    Hope this helps...
    Steve
    Crooked River Ranch, OR
    37
    Talking hf benders do work
    I keep hearing everywhere that you cannot bend tubing with the Harbour Freight benders. Yes you can! 1st You fit the tubing to the die do not use the die marked for that size. 2nd Work slowly jack it up slowly. 3rd if it kinks tape off one end fillit with dry sand tape off the other end and bend away. I have done 5 motorcycle frames with it and three sets of apehangers and I'm neither particularly talented nor intelligent. If you listen to those who say it cant be done you wont do it, same result in the end.
    Oct 2004
    590
    Quote Originally Posted by High Seas
    ccm -
    Jim
    (chair)
    Not to put too fine a point on it but it is offensive and unnecessary. It's sufficient to say chinese built.
    Chris
    Nov 2003
    Lightbulb Chinese benders
    I have a very inexpensive ($49) Chinese built hydraulic pipe bender. It is built to the old 20's Blackhawk bender design, which is a simple hydraulic jack that pushes the shoe. I was VERY pleasantly surprised to find it just as accurate as the more expensive ($5,000.00) models! (admitedly not as easy to use!) I don't think anyone in the US is making them anymore, but Harbor Freight and Homier both carry the 12 ton (my model) and a 16 ton
    http://www.harborfreight.com/cpi/cta...emnumber=35336
    that will even bend three inch schedule 40 pipe. After seeing the quality, I have to admit they are every bit as good as those made in the US. Now some of the other benders, like the quarter scale copy of the Hossfeld can only be described as cheesy...
    Dec 2004
    62
    Htj
    Two more tubing URLs to look at:
    http://www.rorty-design.com/content/CAD_plans.htm
    http://www.gottrikes.com/
    I've been looking at both of these haven't made the decision yet. I am not affiliated with either company.
    Htj
    Feb 2006
    6
    Bender plans in DXF, I will post other plans that I have at home later.
    Doug Morency
    osgoode, ON Canada
    Attached Files Attached Files
    Mar 2004
    761
    Talking
    Combine the tube bender with some hydraulics from a wood splitter.
    Convert to CNC of course (keeping forum posts CNC related)
    Dec 2005
    3319
    Senna: the Mother Earth link took me to a main page and couldn't find the link you posted to a bender.
    Suggestions??? ( outside of joining)
    Feb 2006
    6
Page 1 of 3 123
  1. Home built CNC mill #2
    By jimglass in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2008, 10:29 PM
  2. Home built barfeeder
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2008, 03:50 PM
  3. Another home built router :)
    By steveald in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 07:22 PM
  4. Home Built Router/Drag Diamond Engraver
    By DaSigntist in forum DIY CNC Router Table Machines
    Last Post: 01-24-2005, 08:02 AM
  5. 4-5 axis control recomendations for home built horizontal machine
    By Kmed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2005, 11:04 PM
