588,193 active members*
7,580 visitors online*
IndustryArena Forum > Other Machines > Printing, Scanners, Vinyl cutting and Plotters > How does a 3D printer work? Could one be home built
Page 1 of 2 12
Results 1 to 20 of 28
    Sep 2005
    12
    I was looking at the printers on the Z Corp website. I still do not completely understand how they are able to get the layers built up.
    Can someone explain how these 3D printers work?
    It appears you can buy one for $19K. What technology is needed to build one yourself?
    Jan 2006
    14
    Take a look at this place --> http://reprap.org/
    Thay are trying to build one that is GPL!
    Maybe the CNCZone can speed thing up...
    Jul 2005
    12177
    Quote Originally Posted by garrick View Post
    Do a Google search on 'stereo lithography' and you will be buried in information.
    Building one yourself is probably quite feasible.
    Nov 2005
    There's a couple of different ways to do it...
    depending on what u got and what u want
    first is the medium
    what do u want to get out as the prototype?
    Choices are:
    woodlike
    plasterlike
    plastic
    metal
    Woodlike one operates using butcher paper (plastic lined paper)
    the machine continually pulls out a sheet over the object being formed, and then uses a laser to heat the areas that are to be bonded; increase the power and it becomes a cutter for negative hole removal. Object comes out like a piece of wood, with similar machining characteristics.
    #2 is plasterlike - this uses a fine dust of plaster or whatever, and a nozzle dispensing micro amounts of glue - think of it like an inkjet on steroids; there is a z axis for raising/lowering the object, and a tub for the material being bonded - the arm sweeps across and brushes the loose powder across the top of the object and then the head comes in and sprays it with the glue. then the excess (loose powder) is brushed/blown off and the object is lowered and the next clean layer of loose powder is swept on
    #3 is laser based; there is a polymer that reacts to laser light (UV); the object is supported in a liquid bath of the stuff, and lowered; each layer is drawn on by the laser forcing the liquid polymer to become solid
    #4 is metal sintering - same idea as #2 but you use a metal powder and a much higher power laser - gives u a metallic object which is very porous
    thats the # of the systems I know about
    Apr 2006
    1257
    Quote Originally Posted by MrZack View Post
    I said it before and I'll say it again....a machine that can replicate itself should not be allowed. It will only be a matter of time until some 'genius' writes a nasty program for it telling it to exterminate the humans!!
    Quote Originally Posted by sydspoetry View Post
    Choices are:
    woodlike
    plasterlike
    plastic
    metal
    ...and flesh like!
    Take a look at this:
    http://www.newscientist.com/article.ns?id=dn3292
    http://abcnews.go.com/Technology/sto...1603783&page=1
    Apr 2005
    3634
    It's already been done, the machine would be us humans, the program would be war !!
    Feb 2005
    750
    Could I take parts of ex-wife #1, and ex-wife #2,...oh-my-god this is scary...
    Halfnutz
    Sep 2005
    12
    You guys are a riot. And just for the record I don't want any part of ex-wife #1.
    Nov 2005
    Quote Originally Posted by diarmaid View Post
    ...and flesh like!
    I excluded two variants because they focus on different venues.
    Theres work being done on cellular printing, and electronics-circuit printing.
    Cellular uses inkjet-like heads (actually proto work uses actual inkjet heads) to deposit solutions of cells on a scaffolding paper. Printable Electronics uses something akin to laser printer deposition/fusing of toner on a flexible electronics sheet Somehow I doubted the thread poster wanted to know about these
    Sep 2005
    12
    This is surprisingly doable.
    Apr 2006
    1257
    I excluded two variants because they focus on different venues......Somehow I doubted the thread poster wanted to know about these
    Maybe he wants to 'Print' a machinist for his shop who he can pay minimum wage and work like a dog......or pay no wage.....argg...shhhh.....dont tell anyone I said that....
    Sep 2005
    12
    Machinists? Weren't they all replaced by CNC?
    Mar 2004
    120
    A machinist is just someone who f*^ks around with machines to make more machines ;-)
    embrace enthusiasm to accomplish the task
    Gary Davies... www.durhamrobotics.com
    Sep 2005
    197
    3D printer
    At my work they bougth one of these Z Corp printers and it looks easy to build ( If you think building CNC machines is easy)
    The printer Is working as a inkjet printer. It prints a type of glue into Gypsum powder. The printer head is actually a normal inkjet head. Instead of ink a (sugar solution) is used. The software import STL files. The file is sectioned in step of 0.1 mm. Each section is a bw picture. The part is black and the powder is white. Inside the printer there is two bins. One as reservoir and one to build the part inside. Each bin have a adjustable bottom. controlled by a stepper. When the printer start the Building bin is empty. Then the reservoir step up 0.1 mm and the machine shovel a thin layer of the powder over to the building bin and this bin step down 0.1 mm. Then The print out the first layer/Picture.
    I belive that the most challenging part is to find a software that automaticly sections up a part and generate pictures of the sections. I belive that the hardware could easily been buildt out of an modified A1 plotter or something like that.
    The part I'm holding is an 1/4 scale of an part for an robot. 1 hour printing and ready. very nice machine.
    Apr 2005
    3634
    http://www.vectric.com/WebSite/Vectr...d_features.htm
    Jun 2003
    866
    I like the 3d printer that uses sugar as the medium
    Apr 2005
    38
    Garric, I found this link a long time ago and posted it to a thread by mononeuran. Take a look at the video {I think its 17meg}. The machine is very doable, but it is more the medium "starch" which is very affordable which makes this process very attractive!
    http://www-rcf.usc.edu/~khoshnev/RP/...0Sintering.htm
    Oct 2006
    669
    check out: http://www.desktopfactory.com
    When this hits the market, expect to see some scrambling from ZCorp and 3D Systems to come up with an "affordable" desktop version of their machines
    Sep 2005
    197
    Have you used this software? The number of sections could be like 500. So the program have to do this automatic I think. And output an image black & white to print. As I understod form the info about this program you could cut and section the part but manually
    Sep 2010
    Hi Guys , My name is TJ.
    I have everything posted here on my website.To make a printer and tons of info . Kits will be available soon.
    -SNYGRO- a 3D Rapid prototype printing | TJ Snyman Comments/Forum
    The whole world of rapid prototype printing is leaning towards Digital slice PROJECTING A UV Source . Inkjet is one dot per time takes too long and cumbersome even laser can only shoot one line or dot at a time. Projection do one whole layer at a very fine resolution in 8 seconds. how can you beat that!
    TJ Snyman
Page 1 of 2 12
