587,782 active members*
2,848 visitors online*
Results 1 to 7 of 7
    Jun 2007
    36
    Suitable Stepper Motor
    Would this stepper motor be suitable for a router??
    http://rswww.com/cgi-bin/bv/rswww/se...0&cacheID=ukie
    Jun 2003
    3312
    You need to post the number or something, the link doesn't work. Says the search has timed out.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jun 2007
    36
    Sorry about the that the website is
    http://www.rswww.com
    the stock number is: 494-9858
    or 455-2533
    Thanks:wee:
    Jun 2003
    3312
    Those are stepping linear actuators. They have a stepper motor but they have a short travel.
    Jun 2007
    36
    Which one would be suitable on that website, i am trying to keep the cost extremely low!!
    I have found this one else where.
    Quality product from MINEBEA this NEMA 23 frame motor features:
    Rated current 1.2A Holding torque 0.314Nm (3.2kg-cm)
    Rotor inertia 0.55kg-cm2 Detent torque 0.0492Nm (500g-cm).
    Output shaft 6.3mm dia x 19mm long 4-connections flying lead 115 mm long
    Body 56.5mm dia x 40mm long with 57mm square mounting face having a 5.2mm dia mounting hole in each corner on an approx 47mm square.
    Jun 2003
    3312
    Go find some old junk hp laserjets and pull the steppers from them.
    Jun 2007
    36
    Do all printers have stepper motors because i have two old ones sat on the side doing nothing. For new ones, would these be any good.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...4428&rd=1&rd=1
  1. Suitable circuit for using stepper as power feed
    By staffordshirech in forum CNC Machine Related Electronics
    Last Post: 07-13-2009, 03:38 PM
  2. Copier Stepper motors suitable for a cnc project?
    By rhinoman in forum Stepper Motors / Drives
    Last Post: 12-19-2008, 01:36 AM
  3. what's suitable Stepper motor for cutting wood?
    By SeQueNcer in forum Stepper Motors / Drives
    Last Post: 08-03-2006, 11:35 PM
  4. Is this motor suitable for g320
    By gcamlibel in forum Gecko Drives
    Last Post: 04-16-2005, 06:00 PM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
