586,033 active members*
3,077 visitors online*
Results 1 to 2 of 2
    Feb 2008
    92
    CNC router 2.2kw 110v VFD?
    Does anyone know where to get a 2.2kw 110v VFD for a 6090 4 axis router? I want to upgrade to a spindle that uses an ER16 or ER20 collet and it doesn't look like they make one for a 1.5kw 110 controller.
    thanks
    15362
    Re: CNC router 2.2kw 110v VFD?
    Quote Originally Posted by MadPickinSkills View Post
    thanks
    You are not going to get much out of a 2.2Kw that uses 120v NA Power Supply using 240v NA Power supply you need 25A to run this spindle
    They don't make them for a reason, larger cutters need more power, hence the different ER Spindle sizes
    There is no such thing as 110v 3Phase power, this is a Chinese thing, they make these Spindles for buyers that don't know any better, to them a sale is a sale don't fall for it as many have if you only have 120v supply then you have to live with the max you can use which is 1.5Kw and this is right at the max also
    Using 120v your 2.2Kw will give you around 800w so you won't drive the bigger cutters that this larger ER spindle can use
    Mactec54
  1. VFD 110V-110V parameters setting
    By Gautier in forum CNC Machine Related Electronics
    Last Post: 11-12-2021, 05:17 PM
  2. 2.2kw of power on 110v spindle?
    By Odinsbeard in forum CNC Machine Related Electronics
    Last Post: 07-15-2020, 02:14 AM
  3. Trouble with Huanyang 2.2kw 110v spindle/VFD
    By Kagstand in forum Spindles / VFD
    Last Post: 02-20-2020, 01:50 AM
  4. Replies: 11
    Last Post: 10-14-2018, 09:54 PM
  5. 110v 2.2kw VFD/spindle help
    By factory5150 in forum Spindles / VFD
    Last Post: 08-10-2017, 01:16 AM
