588,216 active members*
4,431 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Stepper driver, breakout board problems
Page 1 of 2 12
Results 1 to 20 of 34
    Oct 2006
    100
    Hi everyone
    I purchased some nema 34 stepper motors, drivers and breakout boards for use on a 4x4 cnc router from a chinese company. I have some serious problems in the setup if anybody can possibly help. Support is now non existent from them and im stuck!
    2 main problems, we cant get the e-stop and any limits to work,and the Z axis loses steps no matter what pulse setting I seem to try. Have got 2 identical breakout boards and they both act the same so maybe its something i have overlooked.
    The motors say 3.5amp on them but the motor drawing says 5.6A/phase? The drivers they say were matched and are model SD-2H086MB.
    Power supply is 48v, 10.4amp. The 2 Y axis motors are geared 1.5:1 and the Z axis motor is 1:1. The ballscrews are all 5mm pitch.
    All technical docs are attached. Would greatly appreciate some guidance to maybe sort one problem at a time. Possibly discover why no limits etc are working. Maybe someone has had this board.
    Thanks, Dougie
    Attached Thumbnails Attached Thumbnails wantai 002.jpg   wantai 003.jpg   wantai 006.jpg   wantai 007.jpg
    Mar 2010
    371
    What software are you using this with? If it's Mach or EMC, perhaps we can help. If it's something else, it will be harder.
    Oct 2006
    100
    Using mach3 software, set up according to their instructions. I am wondering if perhaps its wired incorectly or needs something to bring the limits on
    Mar 2010
    371
    Okay, we can help with Mach.
    Does ANYTHING appear to work with the board? Trying to figure out if Mach is able to see the LPT port the board is on.
    If it doesn't, then you have an addressing problem = the board's address is not what Mach thinks it is.
    If something appears to work, then we need to figure out what is in your config that is wrong. You might go into the diagnostics panel. In the center right, you will see LEDs that show the state of the pins. Try hitting some of your limit/estop switches and see if any of the lights change. If they do, we can figure out what is happening.
    I assume that one side of the switch is connected to power supply ground. The other side would be connected to the BOB. Measure the voltage with a switch in both states, and tell us what the voltages are. One them should be zero volts.
    Oct 2006
    100
    Yes I have the 4 motors working although Z stalls no matter what pulse setting I seem to use. The motor settings in mach all give the correct distance moves.
    When I press a limit switch if I put them on pins 10,11,12,13 it lights up an LED on the board to indicate it gets a signal but when I autodetect on mach it picks nothing up. However pin 10 works.
    Yes one side of the switches are to ground. If I put the e-stop in pin 10 it works 3.85v when pressed. If I put the limits in pins 11,12,13 I measure 0v normally and when pressed 2.6v, 3.7v and 3.5v but the status pins in mach dont change to indicate a response. I have tried a different cable and the other board but nothing.
    Dougie
    Looking at your photo's it looks like you have some "Daisy Chaining"
    of the cables going on can you confirm which wires are coming from what and going to
    where.
    Andy
    PS where abouts in the UK are you?
    Mar 2010
    371
    Good.
    Let's make ONE thing work, and then go on to the next. How about E-Stop?
    You said pin 10 works. Make pin 10 E-Stop. Don't use autoscan, manually configure pin 10 to be E-Stop in pins and ports. Use the same port as the motors.
    You said you measure 3.84V when pressed. That sounds good. It means that the switch is normally low, and goes high to activate. It should measure close to zero when at rest.
    You should be able to get E-Stop to work with pin 10, and the right active setting. You can confirm it works easily enough, right?
    May 2007
    380
    I just went through some of these problems. Even though I used shielded cables with proper grounding, I have a lot of electrical noise. I ended up with a .01 mfd capacitor (its all that I had) across the limit switch terminals on the breakout board. I also had to set the "debounce" value to around 7000, in the general config screen.
    John
    Oct 2006
    100
    Hi Guys
    The daisy chaining is the pulse and enable (+5v) between the drives which I assumed would be ok to do. I am in Lancashire UK, near Burnley.
    Brtech the E-stop on pin 10 works and if I put a limit switch on pin 10 it works but no other input pins work. Not sure what those little toggle switches on the breakout board do.
    Johnmac did the capacitor and debounce sort your problems? I am not sure its that as the limits do give a good reading when they change state, just nothing is being outputted through the 25 pin port.
    Its impossible to trace them.
    Douigie
    I would avoid any daisy chaining, not sure what you mean by the pulse being daisy chained.
    Andy
    May 2007
    380
    Yes, for me that combination fixed my problem. When I first started troubleshooting this problem, neither the limit or E-stop would reset.
    Even if you discover you have other problems, don't forget about the debounce setting.
    John
    Mar 2010
    371
    Okay, so E-stop works on pin 10.
    Great.
    Put a limit switch on Pin 11. Manually configure it for the right axis in config.
    It should be provisioned identically to the E-Stop except for the pin number, assuming that for the limits the switch reads about 0 when at rest and +3. something when activated.
    I believe you said you could see the LEDs changing on the diagnostic screen when you activated the limit switch. If that is still working, then the configuration should work to detect the limit.
    Just get one to work first. If that works, try another.
    The capacitors aren't needed yet. You need them if your limit seems to be activated when it shouldn't be (like in the middle of a good move).
    Debounce may need to be set to something, but just to get the limit to activate it shouldn't matter. Debounce is needed because a mechanical switch may not cleanly go from off to on. It may bounce between off and on a bit (milliseconds) before settling down. Most microswitches, if that is what you are using, have very little bounce, but you may get some. For a limit switch, bounce doesn't matter, but the way the debounce function works, it also acts as a noise filter, and you may get noise. The capacitor is also a noise filter and you should not need both.
    If you can see the LEDs changing on the diagnostic screen when you activate a limit switch, then the BOB, the wiring and the limit switch is working: configuration is all that is needed. If you can't see the LEDs change, then we have an electrical problem of some sort.
    Oct 2006
    100
    Andy, on the drives it says direction (+5v), enable (+5v) and pulse (+5v). Those are the ones that are daisy changed.
    Set the debounce to 7000 and nothing, there are no LEDs changing on the diagnostics screen in mach3 for pins 11,12,13 which the limits are connected to. The LEDs which were coming on and off when the limits were pressed were on the breakout board itself.
    If I take the e-stop out of pin 10 and put it in the one next to it marked e-stop in the picture it doesnt work. There is something that I am missing I am guessing not software based to allow those pins to work.
    Any ideas what to try?
    Dougie
    What cable are you using from the pc to your breakout board?
    Have you checked that ALL the pins are connected if you can buzz out all the pins from one end to the other just to prove that all the pins are used. Some cables only come with certain pins connected. If you say the LED is lighting on your board but not in the diagnostics this could be your problem.
    Andy
    PS We will leave the daisy chained connections for the moment and come backl to them once you have sorted your limits out.
    Oct 2006
    100
    Its a straight through cable I got with the motors/drives. Checked it with a multimeter and they are all connected.
    I have attached the info that came with everything for the breakout board. Maybe there is something simple in there that I am missing.
    Attached Files Attached Files
    May 2007
    380
    Something you should check is that Windows is assigning the printer port as LPT1, and that it is an EPP type port. You may need to change to EPP in the BIOS. My computer worked in ECP mode, but I have read about other people having problems with that setting.
    One other thing. Mach is most stable when using a kernel speed of 25000. I suggest leaving it at 25000 until everything is working. When you are ready to do a final tuning of the motors, you may need to bump the kernel speed up if you can't get top speed out of your motors. This is a recommendation in one of the Mach support videos.
    John
    Mar 2010
    371
    Try moving a switch to the C3 input. I think you have them on the 8/9/10/11 pins.
    C3 should be pin 11.
    You should see the LED light, and the Pin 11 LED on diagnostics.
    I don't understand how you would get the extra inputs. Mach usually can only see 4 inputs on Pins 10, 11, 12, 13
    Oct 2006
    100
    computer is set to EPP mode and definately LPT1.
    I have tried the switches in C3,C4,C5 inputs. Its just not seeing them. I dont understand
    C8-C13 it gives as XYZ limits but doesnt give them any pin numbers for the 25 pin port.
    Mar 2010
    371
    At this point, what I would be doing is tracing the circuit. Start at the pin and figure out where it goes. It's going to go through some kind of optical isolator, and then, somehow, to the LPT port.
    Oct 2006
    100
    are the optical isolators the little chips? I have tried tracing but none of them directly link up with pins on the 25pin port. I assume they may need switching or something to transmit a signal out.
Page 1 of 2 12
  1. Driver and Breakout board troubleshooting
    By vmipacman in forum Automation Technology Products
    Last Post: 07-06-2009, 11:22 PM
  2. Breakout Board, Driver and Power for nema23 - UK supplier?
    By mnbylcr2 in forum Benchtop Machines
    Last Post: 05-21-2009, 05:47 PM
  3. does this driver need breakout board?
    By dreamci in forum CNC Machine Related Electronics
    Last Post: 09-30-2008, 10:49 PM
  4. PROBOTIX PBX-RF Breakout Board problems
    By artwood_decor in forum Stepper Motors / Drives
    Last Post: 04-15-2008, 09:47 PM
  5. Stepper Driver, Controller, Breakout board, Home switch, ?????
    By perolalars in forum CNC Machine Related Electronics
    Last Post: 10-28-2007, 03:35 PM
