588,487 active members*
5,391 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need help with Steve Bedair Ball Turning Toolpost
    Dec 2009
    Post Need help with Steve Bedair Ball Turning Toolpost
    hey guys, Im trying to make the Steve Bedair Ball Turning Toolpost for a project in my Machinist Class and i want to get made on the Fadal in the shop using mastercam. Im having problems figuring out the correct pocket toolpath for the hold down base. im just starting out on using this program and i do have the tutorial book, but its can only help so much.
    so far when i do a pocket face toolpath with an island, the toolpath doesnt go to the outside of the stock, and i cannot figure out how to bore the hole in the center either. i keep getting MC kinda shruggin its shoulders not knowing what the hell im trying to do. ill post the drawing here so y'all can see what im trying to make. also the other side of the part needs to have a pocket as well, so do i have to do another program like the one with the holes and pockets just minus those?
    how would you program this seemingly simple part into mastercam?
    Revo
    Dec 2009
    80
    Hi, to machine the Ø2.500 island try with 2D High Speed and then choose Core Mill. You will have to select both the stock contour and the Ø2.500 circle. Good luck...
    May 2005
    394
    you can also do it with island facing. select the outer boundary as well as the circle. pocket milling works too. but if you use pocket milling you need to lie to it and create false geometry outside the outer boundary so it will face off past the edges of the part.
    I remember designing and making a ball turning attachment in high school. when I was done with it. I donated it to the school.
    Dec 2008
    3142
    Why use a "Pocket" routine ?
    it is all 2D_Contours
    order of ops - material size = X4.0",Y4.1", Z0.625",
    XY origin = stock centre, Z origin = top of stock minus 0.02",
    hold in a vice by 0.125" maximum.
    - FACE to cleanup
    - 2D_CONTOUR -outside block 0.052" deep
    - 2D_CONTOUR -inside c'bore by ramping
    - all HOLES
    turn over,
    hold in a vice (outside edges ) by 0.35" maximum
    clock centre hole as 0,0, bottom face is Z zero
    - FACE to thicknes
    - 2D_CONTOUR -outside Ø2.5" & use multipasses
    - 2D_CONTOUR -inside by ramping & use multipasses
    part done
    May 2005
    394
    superman, I was merely pointing out that in mastercam there is usually more than one way to accomplish the same task. it all comes down to preference and user ability.
  1. How do I program turning a ball on the end of a shaft?
    By cdntoolmaker in forum G-Code Programing
    Last Post: 01-26-2013, 01:38 AM
  2. turning ball screws
    By meincer in forum Benchtop Machines
    Last Post: 09-06-2008, 08:13 PM
  3. Jay-CADCAM / Steve Arteman
    By Mastercam User in forum Mastercam
    Last Post: 01-17-2008, 03:44 AM
  4. lathe turning a ball screw end
    By margni74 in forum MetalWork Discussion
    Last Post: 12-05-2007, 04:57 AM
  5. turning ball screws
    By Runner4404spd in forum MetalWork Discussion
    Last Post: 02-16-2006, 05:58 AM
