I have made to minor changes to CNC Write. These changes will make old machine G Code files incompatible. Right now there is an "Open Old" button on the machine tab that can be used to open any existing machine files you may have. If you then save them using the save button, that will convert your machine files to new format.
The Machine file format saves all of the settings from the top part of program interface including text height, width, angle . . . Also if you create a machine file with the name "default", that machine file will automatically load every time the program starts.
The new version can be downloaded here CNC Write Download.
Everything else should work the same. You will NOT need a new registration key.
Chris W
