587,691 active members*
3,506 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Hy 400hz vfd + 2.2kw spindle +300eth-ub1
    Mar 2018
    68
    i set up vfd as per mactec54 parameters for hy. What happenned, is that at max speed in controller (24000) i only get 380 hz (22800) on the vfd.
    Documentation of ub1 board says it can only send 9.8v to the 10v signal of vfd. So that might be the issue. Is there a parameter we can trick in uccnc or in the vfd so i Get the 24000 rpm.
    not that it is a real problem to have only 22800rpm, but annoying as a builder
    hugues
    Re: Hy 400hz vfd + 2.2kw spindle +300eth-ub1
    Yes, there is a workaround that I used.
    I set the VFD to 0-5V, instead of 0-10V, and I think I set the Max PWM % in UCCNC to 50%. THis gave me a 0-5V signal from the UB1.
    You could also use a 12V supply to the UB1 to get a full 10V from it.
    Mar 2018
    68
    thanks, i ll give it a try
    hugues
  1. Closed loop with Delta C2000 and 12000rpm 400hz spindle
    By jeeybee in forum Spindles / VFD
    Last Post: 11-15-2019, 02:21 PM
  2. Replies: 3
    Last Post: 01-28-2019, 07:22 PM
  3. Replies: 3
    Last Post: 05-26-2017, 08:27 PM
  4. 1.5 KW 400hz spindle
    By skybox in forum Spindles / VFD
    Last Post: 03-14-2017, 01:57 AM
