588,491 active members*
3,971 visitors online*
    Jun 2007
    5
    Question ANILAM CRUSADER II Problem
    We have a Bridgeport Series I with the Crusader II controller. The problem is the Z-axis is no reading in the + direction, it reads in the - direction. The scales are OK I check them and switched them around with the same results. It trips out the servos whenever you try to move any axis with the manual buttons. I noticed that the Z is slowly moving in the + not reading when the machine is turned on, and I hear a high pitch whine from each servo. Does this sound like a board in the controller.
    Jan 2007
    333
    Any LED's in cabinet indicating status when alarms?
    Aug 2007
    16
    Hook up one axis at a time and move with handwheels to make sure they are counting in right direction. If so, run in test mode to check balance and signal settings,. If you can use meter, check with that instead. Sounds tho that you have z reader head problem.
  1. My New/Old Anilam Crusader M has a problem
    By L98FIERO in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2008, 01:10 PM
  2. Anilam Crusader II - Crusader 2 Training DVDs
    By Mike Mattera in forum News Announcements
    Last Post: 07-09-2007, 03:31 AM
  3. Anilam Crusader M problem
    By Rot Iron Racer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-18-2007, 08:15 PM
  4. Anilam Crusader M DNC
    By hsmcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2007, 11:06 PM
  5. Anilam Crusader 2 Help
    By porsche1220 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2006, 06:37 PM
