I'm using TurboCad 7.0 and all of the sudden I san't see the lines I draw. Black is the selected line color.
I can take a drawing I have created in the past and modify the lines and shapes but can't add to it.
HELP
Hager
HELP
Hager
Sounds strange, did you try to re-install the program? Alternatively, uninstall, delete the TC folder, then re-install. This should clear it. I know you shouldn't have to though!
Thanks Kong,
I'll wait a while to see if there is a quicker fix,
Hager
Right then, simple things to check in the meantime -
Make sure you are working on a visible layer
Make sure line style is set to continuous
Erm, I am scratching around now, but make sure no snaps are active!
I would be interested to know the solution when you find it!
No Luck Kong.
I reinstalled and all is well.
Thanks for you'r tips though.
Hager
