I work for a company that produces “Automation” equipment for the electronics industry…for the most part. Everything from concept to crate is done in-house.
The company is about 8 strong. A boss, accountant, secretary, project manager, engineer, an assembly guy specializing in electrical, myself in the machine shop, and the boss’s son helping out in the shop.
My main job function is to machine parts from drawings. This is done through either conventional or CNC machining. A lot of the parts that come from the engineer are pretty much CNC-only. So, because of this fact, I have taught myself how to use the Fadal, VisualMill, and the basics of G-code.
In addition to machining parts, I also help with assembly and operation (troubleshooting) of the machines we build. This includes anything from wiring up panels, to running pneumatics.
With most of my time spent in the machine shop, my job title still remains “Shop Tech.”
A main reason for wanting to earn more at this job is because I want to buy more accurate measurement devices and more effective tooling….to make myself more productive, oh... and to pay rent. My company does not believe in buying tools. Yes, I said they do not believe in buying tools…or measurement devices. It is like pulling teeth when I request a tool. When a tap is purchased, only one is purchased…the same goes for drills. I have to use my own calipers if I want to be anywhere close to the correct dimension when machining parts. This is because my boss does not believe that the company caliper, which is Chinese and jumps above and below zero about 0.003”, needs to be replaced.
Okay, so I ask the question:
How much should I be getting paid?, (per hour)???
