587,201 active members*
3,076 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Machine parameter edit procedure for FANUC 6T System
Results 1 to 6 of 6
    Sep 2008
    9
    Angry Machine parameter edit procedure for FANUC 6T System
    Dear all
    I have Daewoo PUMA 10 lathe with fanuc 6T control. machine is working ok.
    i want to change the parameters like softlimt for X and Z axis .
    Please give me the procedure to edit the machine parameters .
    I will be very greatfull to you.
    Regards
    Reddy
    24223
    Set ENABLE switch on main PCB, Set to MDI select PAR page set parameter and push INPUT.
    Al.
    Albert E.
    Sep 2008
    9
    Al.
    Dear Al The Man
    I tried with setting the parameter write enable switch and system is showing the alaram 100 and set the selector in MDI mode and try to change the valve, but the system is not accepting any value. I am unable to enter more than 4 letters , the system is not accepting any value.
    I wanted to change the X - & Z- Limit value i.e parameter No 147
    Plaese suggest me to proceed further
    Regards
    Reddy
    24223
    This method has always worked for me?
    I confirmed the sequence as per the manual.
    Are you sure you are in the right parameter page? Not diagnostic or anything?
    Al.
    Albert E.
    Sep 2008
    9
    Al.
    dear Al The Man
    Thank you very much for your quick reply. I followed the same as you expalianed and i am in the PAR page only.
    is any parameter number to be edited before editing other parameters ?
    I tried By selecting all the modes one by one ,but i am not able to edit the parameters
    Is there any other method ?
    please suggest me
    Regards
    Reddy
    Jan 2009
    245
    Just for reference I believe you have to put a "P" then type the parameter then imput?
  1. Machine parameter for Fanuc 6t
    By Mostafa Mohamad in forum Fanuc
    Last Post: 12-02-2014, 10:09 AM
  2. Fanuc 6M machine parameter
    By gowthu in forum Fanuc
    Last Post: 08-12-2010, 03:38 PM
  3. edit key offset parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-28-2009, 03:54 PM
  4. fanuc oi-mc system parameter help leadwell machine
    Last Post: 11-07-2008, 04:58 AM
