I'm trying compensate the Ram error with vertical axis movement in a Fanuc 15M. The parameters are 5481, 5491, 5501-5504, 5551-5554, but how to configure the parameters? what kind of data for compensation point number?
please i need help, thanks!
Do you have the parameter manual for this control? I have never had to do the procedure so I will not be able to explain it, but I have the parameter manual that gives examples of how to do it. LMK
Stevo
great, can you send me the example or a scan of the page?
tankyou very much!!
I hope this helps. Let me know if there is anything else that you need.
Stevo
Thanks again Stevo!!
Your welcome. Any time.:cheers:
Stevo
IS THERE A FUNCTION LIKE THAT ON A O-MD??, I KNOW IT FOR PITCH ERROR, BUT FOR STRAIGHTNESS I THINK THERE IS NOTHING.
I am not sure I will check. I don't know if it matters but is it a lathe or machining center? I show the manuals for the Oi series and the O-mc. I do not come up with anything on the search for a O-MD
Stevo
The only thing I got is parameters for O series. I could not find anything on straightness comp for that control O-md. I will do some more searching when I get time and let you know if I find anything. I have a lot of stuff on the Oi series but SOL on the O.
Stevo
i tried configure the straitness compensation (in the 15M) but with no success and believe that i tried several times with several configurations of points, axis, compensations!... in one of the pages that is posted talks about the option that must be enable (page 240 par. 1). do you now how can i see if the machine have this option enable or how can i enable this option?
Bruno
