587,999 active members*
5,039 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Inserting a reference plane
    Nov 2012
    162
    Hi guys.
    I'm new to MasterCAM but know Solidworks and ACAD pretty well.
    I'm trying to increase my skill level for MCAM and would like to know how to insert a reference plane at an angle to a surface to produce a cut profile. For instance, I have a block of steel that needs a square pocket in it. The bottom of the pocket needs to be 30 degrees from the top. How can I easily draw the shape and then use FBM to cut it? I can import a solid but would like to learn how in MCAM.
    Hope you understand the question as its hard to explain.
    Yoda
    Apr 2003
    3578
    Re: Inserting a reference plane
    Are you asking how to to create a plane to program it at 30° rotation or to draw it in MC? also what version of MC are you using?
    Cadcam
  1. Feed Plane Overwriting Rapid Plane V26
    By Jbrown74 in forum BobCad-Cam
    Last Post: 02-21-2014, 02:17 AM
  2. Plz , HELP : Reference Geometry >>Plane
    By perfect-eng in forum Solidworks
    Last Post: 07-04-2011, 03:52 PM
  3. TCC v3 - keeps inserting G28 - why
    By phil burman in forum Uncategorised CAM Discussion
    Last Post: 06-26-2006, 05:29 AM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
