With chopper driving, ideally, you want >10times the motor voltage, but is it better to do this with a higher voltage motor that has less coil current? Or is it better with a lower voltage motor with less coil resistance? For eg. I could get a 0.5A 12V motor and run it at, let's say 120V or something... or I could get a 2A 3V motor and run it at 30V. Is there a downside to having more current through the coils at higher speeds?
The reason I am asking is because my supply considerations are limited and at the moment, not yet designed.
Thank you,
Phil
