588,049 active members*
4,022 visitors online*
    Feb 2008
    Open Steady rest
    Hi all, hope this is in the right spot! I have an sl-3 mori lathe that we are using to make some longer parts with. these are about 1" in dia. I've run and programmed cnc lathes before, but never been involved with a steady rest. This will be for production @ approx 100 pcs/per part. Can anyone give any advice/sources for a steady rest? TIA, and let me know if I'm in the wrong place!
    May 2007
    781
    Long time ago I run a CNC lathe with one of these follower rests, turning tapered gun barrels. Don't remember having many problems with it.
    http://www.smwsystems.com/Chucks/Stehome.htm
    They are kind of proud of them, but we were doing thousands of barrels per month.
    http://www.smwsystems.com/Chucks/Prices/omnirest.htm
  1. rest machining
    By camtd in forum BobCad-Cam
    Last Post: 09-05-2007, 12:52 AM
  2. Haas VF2 , master cam, catia v5 vs the rest
    By aussie28 in forum Haas Mills
    Last Post: 08-13-2007, 04:31 AM
  3. Follower rest and long narrow contour
    By jime in forum MetalWork Discussion
    Last Post: 03-27-2007, 11:53 PM
  4. Steady rest auto self centering work
    By trh400 in forum MetalWork Discussion
    Last Post: 12-22-2006, 07:00 AM
  5. Curiosity question - compound rest angle
    By mxtras in forum Mini Lathe
    Last Post: 02-13-2006, 06:41 PM
