Originally Posted by
sandefuj
Are you talking about the dimension tool that you use to size lines circles and such? I just made up the rectangle example for simplicity; the part I drew is complicated lots of 3D contours, added planes. I was hoping I could just rotate the part about the X axis and have the software change all the X’s and Y’s.
Are you planing on machining this part?? If so, what CAM software are you using?? You could import your part then rotate it later in the CAM software.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
