588,224 active members*
4,605 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Aug 2004
    3215
    Joe's G0704 Conversion
    Here is my CNC Conversion.
    Travels are:
    X=19.5
    Y=12"
    Z=13"
    G540, 320oz motors With 2.8 mH low inductance (specifically spec'd for the G540), 50vdc
    I got Hoss DVD and using other examples made some modifications. (Highly Recommend it)
    Right now I have a 3" Column Spacer, Still need to Mill the Head Spacer's to take advantage of the 12" Y travel. I will let the G0704 make them, My CNC Mini MIll is not large enough.
    I did not do the Z-Slide Vertical Flip as of yet not sure If I will or not.
    I plan to get Another Saddle and make the one shot oiler in due time.
    Using two 50lbs Struts for counter balance.
    And need to make way covers for a large Y Travel, Then onto the Enclosure.
    A Quick Video Of machine running 200ipm I will take it higher when I get some free time to see what it will do. but realistically will not be cutting that fast.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Nov 2009
    4415
    Nice work.
    I am a little suspicious of the 12" in Y. I have a feeling that once 1/2 the width of the carriage is off of its ways, stability and flex will be off the hook. I would think the weight of the vise alone would be enough.
    Put a dial indicator in the Z and run the table back and forth in Y and check how much the table tilts once it is unsupported.
    Aug 2004
    3215
    Quote Originally Posted by Fastest1 View Post
    Nice work.
    I will not be traveling more than 1/2 the saddle width. Most of my cutting will be done with fixtures. and if I use the vise I am limited to the 5-6" travel of the jaws of the vise. We will see how it works when I start cutting parts etc.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Great work Joe, excellent workmanship!
    Those are almost router like travels.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Aug 2004
    3215
    My Base and Column Spacer.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2004
    3215
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Thanks, Its nice comming from you as the teacher..
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Just a note on cutting thru the rear of the casting, when I did that on the old x2 base extension there was a noted difference in the distance between the dovetails where the cut was made. I measured it with a couple short pieces of ground drill rod in the dovetails.
    iirc there was .010 from front to back, had to put in a spreader bar to get it back even.
    Might not be as pronounced on the thicker g0704 base but still worth checking, if it needs spread a couple pins in your spacer could keep it true.
    Hoss
    Aug 2004
    3215
    Hoss
    Yes I had thought about that, and is why I have the Column spacer bolt to the outer portion of the Base on each side to help prevent movement or settlement of the base over time. I measured mine and it apeared to be fine, but time will tell.
    I do not plan on doing large hogging of material, and making light cuts mosly in aluminum etc.
    Thanks for the heads up. The casting is allot beefier than my X2 HF clone.
    Aug 2004
    3215
    My Auto Retracting Way Cover.
    G0704 Auto Rollup Way Cover - YouTube
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2010
    630
    Quote Originally Posted by joecnc2006 View Post
    My Auto Retracting Way Cover. G0704 Auto Rollup Way Cover - YouTube
    What exactly did you use for the way cover. I did the same thing using a blackout shade.
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    Aug 2004
    3215
    It is a PVC material from lowes it is used for a moisture barrier for tubs and showers, they can cut you a foot off I think it is 5' wide and 6.00 a foot.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2010
    630
    Okay. So what are you using it with? A roll up shade?
    Aug 2004
    3215
    Quote Originally Posted by Connor9220 View Post
    Yes, I took the non spring loaded end off and cut it down to 10" wide then put the end back on the other side I took the rachet gear off the other side.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2010
    630
    Same thing I did. http://www.cnczone.com/forums/bencht...ml#post1195439 Only I used the shade as is.. I didn't re-wrap it with that moisture bearer stuff. You have a close up of the brackets and the way you mounted it ?
    Aug 2004
    3215
    thanks for the link, I had not seen yours before, How is it holding up for you and how many hours you think you have on it?
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2010
    630
    To be honest. I don't have much time on it. And I ripped a hole in it. My vise is extended over the back of the table. Got too close to it. I want to get a new vise. On of those nice CNC style ones vs the one I have now. To fix the cover. I'll just unroll it some more and cut off the bad section.
    Aug 2004
    3215
    The G0704 making it first cuts. Machining the first Portion of my Head Spacers.
    First Part - YouTube
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2004
    3215
    G0704 Cutting
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2004
    3215
    Finished the First Part of my head spacer, now to make the back plate.
    I already have it drilled out.
    Attached Thumbnails Attached Thumbnails IMAG0188.jpg   IMAG0190.jpg   IMAG0191.jpg
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Aug 2004
    3215
    Both Pieces of my Head Spacer are complete. The Head is extended out 5" to take advantage of the 12" Y-Axis travel.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
Page 1 of 2 12
  1. G0704 CNC conversion grinding
    By bucsmike in forum Benchtop Machines
    Last Post: 05-19-2013, 10:37 PM
  2. New G0704 - CNC Conversion
    By feederic in forum Benchtop Machines
    Last Post: 11-21-2012, 05:42 AM
  3. G0704 X axis conversion
    By pemko in forum Benchtop Machines
    Last Post: 02-28-2012, 03:07 AM
  4. G0704 Conversion
    By rcazwillis in forum Benchtop Machines
    Last Post: 07-17-2011, 03:27 PM
  5. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
