588,225 active members*
4,648 visitors online*
    Mar 2009
    6
    T MSR AUTO MODE IN MAZAK!
    Hi Gents,
    In v655/80 MAZAK (M32B) machines tool length measuring unit I wants to change the position, my problem is T MSR auto mode working in particular position only, we can change that? Any option is there pls assist. Thanks.
    Mar 2005
    988
    Yes, you can change the position. It's an R parameter but I can't remember which one right off the top of my head. Maybe someone with the list can chime in...
    It's just a part..... cutter still goes round and round....
    Jan 2009
    55
    r parameters
    The tool setter position and height are set in the R parameters i belive around R2392. Look in the electrical diagram book there will be a list of them in there. I know there is also a R parameter that allow the mesurement of endmills. Sorry i dont have a book at home or i would tell u that the actual parameter numbers are.
  1. Drip feed mode for Mazak M32
    By CimUser2000 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2010, 01:55 AM
  2. Mazak QT15 with T32-B control does not switch to automatic mode
    By MarkusFunk in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-06-2008, 03:54 AM
  3. Mazak Integrex 100Y Subspindle Milling Mode not working
    By mzbik in forum G-Code Programing
    Last Post: 01-22-2007, 07:59 PM
  4. Using G12.1 Milling Mode on a Mazak Integrex
    By mattclubb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-23-2006, 06:24 AM
  5. Single line mode works well, Auto is not soo good??
    By Darc in forum CamSoft Products
    Last Post: 10-26-2004, 09:29 PM
