I have a part 1.5" thick 4140 I just need to rough out a 15* wall in them. I am milling this out with a 3/4" .06 rad corner end mill. I want to start at the bottom and work up? this way I will use the whole cutter, not just the last 1/16th of it.
I can not figure out how to make it work in this direction? if its even possible? The finish with "stair steps" is not a problem in this job at all.
