587,201 active members*
3,067 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Troubleshooting cut path.. is it a cam issue or mechanical?
Results 1 to 10 of 10
    Feb 2015
    Hey all,
    New to the forums and new to operating a cnc.
    We started creating a vacuum table and for some reason the channels are not spaced evenly like they should be. We cut this on multiple small trials on different material, mdf..etc and it is consistently cutting unevenly. In the mach3 preview window the spacing is perfect as it should look and every time we cut this happens
    The weird thing is the spacing is exact between every other one but as you can see one gap in the channel is bigger than the other.
    Excuse me if this is obvious but I've done a lot of searching and cannot really figure it out. We do have a "hobby" machine if you would call it that, it is not heavy duty but I do not think this is a deflection/backlash issue since the material is not very dense and we are running it smoothly... my understandings of those may not be entirely correct either but I really need to get this figured out as right now we do not need exact cuts to make this vacuum fixture work but we will need very accurate cuts soon. What is weird is that it is even in the error so it makes me believe it is a setting somewhere.
    I also tested the motors to make sure they jogged the correct amount on the DROs with a measuring tape on the gantry so it seems like it isn't a tuning issue... help!!? haha
    I attached a picture to show on a test piece of particle board what I am talking about.
    If this thread needs to be moved to another section please do so. Thanks for your help
    Attachment 267816
    ~moana
    Re: Troubleshooting cut path.. is it a cam issue or mechanical?
    My first guess would be deflection.
    Is the bottom left corner the end of the cut? If it is, then it's most likely deflection.
    Can you post the g-code?
    Apr 2004
    5741
    To me, it looks like your CAM program isn't set to cut down the middle of the lines you laid out, but it's cutting to one side of them. The error you're looking at is too regular to be lost steps or a mechanical problem, and it seems to be off by a factor that's pretty close to the radius of your tool.
    Andrew Werby
    Website
    Nov 2012
    68
    Try running the program only .010 deep, if it does the same thing then its not a deflection issue. It may be a cutter comp. issue. Look at the g-code, is it switching from a G41 to a G42.
    Feb 2015
    Thank you for the replies everyone
    The above picture is when we tried cutting the vacuum channels with a 1/4 inch bit. The spacing between each channel was supposed to be 1/4 inch but it ended up having 3/8 inch for the wider width and the smaller one is 1/8 inch wide.
    The g-code posted below was when we decided to run the channels with a 1/2 inch bit on a sheet of mdf. I do not have the measurements of these channels but they were inaccurate and consistently off just like the 1/4 inch bit was on the particle board picture.
    I know the machine we are using isn't rock solid like some fully welded one but we didn't run these at ridiculous feeds and it is the same freakin consistent inaccuracy each time. I am about to pull some beard hair out haha! It is off on both ends of the sheet of mdf the same amounts!! AHHHH!!!!
    N0010 (Filename: vertical vacuum channels.txt)
    N0020 (Post processor: Mach3.scpost)
    N0030 (Date:07/02/2015 Time:18:05:40)
    N0040 G20 (Units: Inches)
    N0050 G40 G90 G91.1
    N0060 F1
    N0070 (Part: vertical vacuum channels)
    N0080 (Operation: No Offset, Default, T6: Mill/router, 0.5 in diameter, 0.25 in Deep)
    N0090 S1000 (Mill/router, 0.5 in diameter)
    N0100 T6 M06
    N0110 G43 H6
    N0120 G00 Z0.1500
    N0130 S1000 M03
    N0140 X47.0000 Y1.7500
    N0150 Z0.0197
    N0160 G01 Z-0.250 F11.811
    N0170 Y95.2500 F2834.6457
    N0180 X46.0000
    N0190 Y1.7500
    N0200 X45.0000
    N0210 Y95.2500
    N0220 X44.0000
    N0230 Y1.7500
    N0240 X43.0000
    N0250 Y95.2500
    N0260 X42.0000
    N0270 Y1.7500
    N0280 X41.0000
    N0290 Y95.2500
    N0300 X40.0000
    N0310 Y1.7500
    N0320 X39.0000
    N0330 Y95.2500
    N0340 X38.0000
    N0350 Y1.7500
    N0360 X37.0000
    N0370 Y95.2500
    N0380 X36.0000
    N0390 Y1.7500
    N0400 X35.0000
    N0410 Y95.2500
    N0420 X34.0000
    N0430 Y1.7500
    N0440 X33.0000
    N0450 Y95.2500
    N0460 X32.0000
    N0470 Y1.7500
    N0480 X31.0000
    N0490 Y95.2500
    N0500 X30.0000
    N0510 Y1.7500
    N0520 X29.0000
    N0530 Y95.2500
    N0540 X28.0000
    N0550 Y1.7500
    N0560 X27.0000
    N0570 Y95.2500
    N0580 X26.0000
    N0590 Y1.7500
    N0600 X25.0000
    N0610 Y95.2500
    N0620 X24.0000
    N0630 Y1.7500
    N0640 X23.0000
    N0650 Y95.2500
    N0660 X22.0000
    N0670 Y1.7500
    N0680 X21.0000
    N0690 Y95.2500
    N0700 X20.0000
    N0710 Y1.7500
    N0720 X19.0000
    N0730 Y95.2500
    N0740 X18.0000
    N0750 Y1.7500
    N0760 X17.0000
    N0770 Y95.2500
    N0780 X16.0000
    N0790 Y1.7500
    N0800 X15.0000
    N0810 Y95.2500
    N0820 X14.0000
    N0830 Y1.7500
    N0840 X13.0000
    N0850 Y95.2500
    N0860 X12.0000
    N0870 Y1.7500
    N0880 X11.0000
    N0890 Y95.2500
    N0900 X10.0000
    N0910 Y1.7500
    N0920 X9.0000
    N0930 Y95.2500
    N0940 X8.0000
    N0950 Y1.7500
    N0960 X7.0000
    N0970 Y95.2500
    N0980 X6.0000
    N0990 Y1.7500
    N1000 X5.0000
    N1010 Y95.2500
    N1020 X4.0000
    N1030 Y1.7500
    N1040 X3.0000
    N1050 Y95.2500
    N1060 X2.0000
    N1070 Y1.7500
    N1080 G00 Z0.1500
    N1090 M05
    N1100 M05 M30
    Once again, thank you for any help you may offer! I am ever grateful and would love to show you guys what we are doing if I can get this cnc accurate!!
    Best,
    Moana
    Oct 2013
    8
    First off I would test cut on something that cuts good like mdf not laminate, that's pretty hard stuff. Second I would look at your tool run out. And lastly check your backlash.
    Feb 2015
    Per my last post we did run through mdf. Same issue with the 1/2 inch bit on that.
    Testing backlash, going to have to get a how-to on that although I'm sure there's posts on it. Tool run out..it isn't wobbling?
    Oct 2013
    8
    From experience I've learned that the collets that come with most routers are anything but precise. The second issue could be if your router is perpendicular to your table. Manually plunge the bit down and move it a set distance in both x and y. Measure the widths as well as the lengths of those two slots. If your bit had runnout both slots will be oversized the same amount. If the router isn't square to the table the slots will probably be different sizes.
    Jun 2013
    1041
    Try making the cuts all in one direction and see if that changes the spacing. Also what bit are you using to cut with?
    Ben
    The circled area all indicate deflection. It looks like there may be other areas as well, but it's hard to tell from the chipping.
    With the spindle off, and no bit in the collet, grab the collet and push and pull in all direction. See if you can find something moving, or if the entire machine is flexing.
  1. Software issue or mechanical
    By GITRDUN in forum Mach Software (ArtSoft software)
    Last Post: 04-24-2014, 10:09 PM
  2. dynamic path feed issue
    By daytona81 in forum Mastercam
    Last Post: 08-25-2013, 04:19 PM
  3. Toyoda mill path issue
    By Garban in forum G-Code Programing
    Last Post: 04-14-2012, 06:33 AM
  4. EZ PATH II coolant issue
    By jaredsparks in forum Bridgeport / Romi Lathes
    Last Post: 03-20-2012, 02:18 AM
  5. Tool Path Generation Issue
    By ianober in forum BobCad-Cam
    Last Post: 03-11-2009, 07:42 PM
