587,238 active members*
3,873 visitors online*
    Oct 2011
    10
    Another Mystery Reset
    I've been milling wood a couple years no problems. I set up a vertical clamping station at one end of the bed. The whole job is only 1" x 5" X -.47".
    I keep getting hard limit switch resets every few minutes even though there is no input indicator in diagnostics. I moved both debounce settings from 0 all the way up to 4000. I even altered the pin number on the eStop (All switches hooked to this one) to turn it off but it still resets. Something here I don't understand.
    It's noise or switch bounce. Try setting the debounce to 10,000, or even 20,000, just to get it to work.
    24223
    Make sure all machine sections and motor frames are bonded to earth ground, gantry included.
    Al.
    Albert E.
  1. R&P Mystery
    By Treischl in forum DIY CNC Router Table Machines
    Last Post: 06-05-2011, 01:56 AM
  2. Mystery
    By SteveY in forum Solidworks
    Last Post: 10-25-2010, 05:50 AM
  3. DYNAPATH MYSTERY!!!
    By Osunator in forum G-Code Programing
    Last Post: 05-04-2010, 10:26 PM
  4. mystery function in v23
    By MSPP in forum BobCad-Cam
    Last Post: 03-13-2009, 06:37 PM
