587,149 active members*
5,527 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Questions about pcb-gcode.
Hybrid View
    Feb 2004
    466
    After I run the pcb-gcode script in Eagle and the bottom layer is generated and the drilling is generated I am not sure about this: Do I need to flip the pcb to drill it? Because if I deselect the "Generate top drills" and leave only "Generate bottom drills" there is no output file for drilling. I am confused.
    Nov 2005
    30
    That's strange. I just re-checked it here and it works fine. Is there something off with your layout? Maybe just try a board with some vias on it.
    I'm using Eagle 5.3.0
    Good Luck
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  2. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 06:40 PM
  3. some questions about gerber & gcode
    By michaeljun in forum LinuxCNC (formerly EMC2)
    Last Post: 10-17-2008, 05:42 PM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
