I've been looking around for a way to set the two tables of our CNC mill to work as one (we have a really large wood panel to machine).
What I've been told needs to be done is set the V-axis to take the Y-axis commands as is own too, so they'll do the same thing at the same time.
The controller is a GE Fanuc 160i-MA
the support guy told me other Fanuc models he knows have a switch "table coupling" on the panel itself, but not this one.
The other option he gave me was that there are sub-programs numbered in the 8000-9000 within the machine itself for just that purpose.
I found one, O9002, labeled "ASSE V TRASFORMATO IN Y" (Axis V Transformation in Y, I made sure it was that) but after having a look and a couple tests with the other similar sub-program (ASSE Y TRASFORMATO IN V), it would seem that they only do change the working axis. Y becomes V, or for the other one V becomes Y (which was already the case, reason why I thought I wasn't using it properly), not the master/slave link between thoses two axis I'm looking for.
I'm looking if there is not a way to use thoses sub-progs to do what I want...
Any help on how to synchronize the tables with that controller would be appreciated! thanks
