587,460 active members*
3,601 visitors online*
    Feb 2007
    314
    tool holder stuck in spindle
    I have a hardinge vmc-1000 and tool holder sticks in the spindle. Air blast seems to work well. I think is due to the coolant cause after cleaning and oiling tool holder and spindle, evrything work well, but only for few hours. coolant is cimtech 304MA and i use water from the public distribution, so maybe there is to much mineral but i didn't have this trouble when i used cimstar 40B coolant. Any idea???
    Feb 2007
    1084
    Maybe an acumultor in the air supply line to give the drawbar a litte more "umph" would do the trick, easy answer is go back to your old coolant if you wern't having problems.
  1. tool holder geting stuck in spindal
    By skippyfix in forum MetalWork Discussion
    Last Post: 07-12-2009, 01:39 AM
  2. tool holder stuck in spindle
    By Runner4404spd in forum Fadal
    Last Post: 03-02-2009, 03:24 PM
  3. ER-16 Collet stuck in ER-16 Tool Holder
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2008, 08:04 PM
  4. Tool stuck in spindle
    By PBMW in forum Haas Mills
    Last Post: 08-23-2008, 02:44 AM
  5. Mini Mill Tool Stuck in Spindle
    By esphobby in forum Haas Mills
    Last Post: 02-22-2006, 04:29 AM
