Hello all,
If this has already been done, let me know. Send the link to the post if you have it. So far, I have not seen this method.
Here is a concept that I intend to use on my machine. The complete machine is based on the JGRO plans with some modifications. The first modification I intend to implement is described here. Please check out the pictures.
The angle iron will be supported by the machine frame allowing the pipe to be freely suspended (just like JGRO's pipes). Pic 1 shows how I cut slots for the end mounting bolts. This allows me to adjust the pipes further away or closer to the angle iron by turning the appropriate nuts. Pic 2 shows the rails with a bearing assembly zip tied in place. Pic 3 is a close-up of the support adjustment bolts. Pic 4 is a close-up of how I bolted the ends of the pipe to the angle iron. Pic 5 and 6 are of the whole rail assembly. In order to flex the pipe, you would need to flex the entire assembly. The rail shown is only 3ft long (x-axis) but I plan on having 5ft rails on my y-axis. That's the main reason I'm trying to support the pipe.
My adjustment bolts are obviously way too long. They are what I have available until my next trip to the store. So what do you think? Please reply with your comments, suggestions, criticism, or whatever you have to offer. I'm looking for possible weaknesses and methods of improvement. After I get some feedback, I'll move forward building the rest.
What I like best so far, is I was able to make the whole thing using my drill press and a few clamps. The worst part was getting two perpendicular holes on one end of the pipe to be perfectly in line with two perpendicular holes on the other and of the pipe. My fabrication methods definitly need improveing. I came very close to perfect but, one of my holes is a little bit off. I had to wrestle with it a little while assembling. One other dawback is it adds considerable weight to the gantry.
-Rocko
