Found this on Ebay... If the spindle for the thing will deal with the stress, I'm wondering if it might be interesting to mount a larger stepper?
CNC Router Rotational Axis, the 4th Axis, A axis for the engraving machine 1650 | eBay
I posted that a while back, I don't know if anyone has taken the "plunge" yet.
That's who I got my pendant from so they aren't bad to deal with, ok shipping speed.
With a 50:1 ratio a bigger motor isn't going to gain much, it should already have tons of torque.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Hmm... I might... I'm basically thinking, however, that if I can find a spindle that I can use with an R8-mounted chuck, that could also work. I'm not needing huge, and I am a little worried about the worm gear backlash/wear that Warfield speaks of...
Yeah that's what makes a harmonic drive like this is supposed to be so desirable, no backlash.
A typical rotary table 4th axis will need adjusted from time to time and even then backlash isn't likely to be zero.
Hoss
I'll be machining steel, with the largest parts approximately 1.25" diameter, and if I need to, I can deal with smaller cuts (as long as I don't get into the realm of surface hardening). I'm hoping that I can work out a "real" fourth axis, so that I can do real curving cuts, rather than just an "indexer" type of thing (which is what we've got in the shop right now).
The no-backlash feature sounds good, if it really works. But I wonder if it will mount any other chucks besides that 3-jaw - most of the stock I use is square or rectangular, not round.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Looks like a typical lathe chuck on there Andrew with the mounting studs thru the faceplate
so I'd imagine a 4 jaw chuck would fit too at least with an adapter from LMS.
Hoss
Okay, looking like I'm going to be doing one in the next few days... I'm just hoping that it is overall rigid enough to work with steel parts. And I may be looking for a four jaw at the same time too...
Cool let us know how it works out for you!
It's a nice compact unit from the pics.
JTCUSTOMS
"It is only when they go wrong that machines remind you how powerful they are."
Clive James
Any other word on this?
I've been eyeing it for a while, and am unsure if I should pull the trigger.
adrian
This 4th is a topic in the DIY router forum
linky:
http://www.cnczone.com/forums/diy-cn..._4th_axis.html
Buyer adapted a fancy chuck, unclear if min-lathe chucks are a bolt-on affair
Anyone who says "It only goes together one way" has no imagination.
