587,875 active members*
3,525 visitors online*
Results 1 to 13 of 13
    Feb 2006
    4
    homemade lifting bar pics!
    Check out this lifting bar that I machined at work during my lunch break. I used some 3/4" plate that I found laying around the shop. Now all I need is a mill to lift!
    Nov 2005
    201
    Re: homemade lifting bar pics!
    Nice!:banana:
    Aug 2009
    610
    Nice work! That much 3/4" plate must have cost a pretty penny. When I need steel plate I cringe these days! That's true even when buying drops.
    Feb 2007
    1538
    Beautiful work Sonny.
    Here is my rough and ready solution.
    Cheers. keen
    Jul 2007
    1602
    That's scary. If anything happens to the allthread, it will take out a big chunk of the Z casting. Of course in that unlikely scenario one would likely have bigger problems to deal with.
    bob
    Feb 2006
    7063
    Quote Originally Posted by rowbare View Post
    bob
    Not to mention the very large bending stress on the single bolt the chain hook is attached to.
    I don't like using chains at all for lifting these machines. I use heavy duty ratcheting cargo straps. Not only are they more than strong enough (Each strap is strong enough to hold the entire weight of the machine by itself, and I usually use 3-4 of them), they won't damage the paint or sheet metal, and they can be adjusted easily, even with the full weight of the machine on them, to keep everything level. They're even cheaper than chain.
    Regards,
    Ray L.
    Feb 2007
    1538
    Hi guys.
    It was fine - I have lifted several times with this. Don't worry to start with I overloaded the machine with another 100 kilos while just off the floor to check all was well.
    Although to be fair I lost that strap and made a slightly heavier one with a shackle connection when my second tormach arrived.
    Keen
    Aug 2009
    610
    Wow Keen that is a pretty wild design. Here in the states we would call that Gettin R' Done Redneck style! The time I worry the most when moving these machines is when you are putting them back on their stands and have to impart a twist or pressure during the final descent to get the base to line up with the pads on the Tormach stands. When I designed the welded box tube base for my 2nd machine (the much lighter 770) I tried to provide a very large landing area for the base. I used 2x5" wide 3/16" thick box tube for the landing areas (run across the entire span) and it simplified things quite a bit.
    Feb 2007
    1538
    You all make me nervous now! But I climbed on the machine plus some heavy chucks when it was just off the ground and jumped on it - so if it can stand that surely it is fine when hanging high in the sky ......
    less keen
    Aug 2009
    610
    Nicely done!
    Feb 2007
    1538
    Here we are I found a pic - super safe now with a shackle and welded on gusset......
    Keen
    Feb 2009
    152
    Nice work, but in my opinion Keen has a better lifting solution. I have always maintained that the best solution to a problem is the simplest. While you have made a nice piece, the materials and effort involved far exceed it's value as a tool. Even if you are in the rigging business, it is clearly designed to lift and balance only one machine, probably only one time, so it then becomes a fancy paperweight. Keen, on the other hand, accomplishes the same task with little time and materials.
    Aug 2009
    610
    I'm impressed with how clean that machine looks Keen! I can tell that you give it lots of love and attention.
  1. Lifting an 86 QT10N
    By xa-mont in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-16-2014, 11:03 PM
  2. Lifting the beast
    By cyclestart in forum Benchtop Machines
    Last Post: 04-03-2011, 03:50 PM
  3. z axes lifting
    By John Teichman in forum Mach Mill
    Last Post: 02-11-2008, 04:12 AM
  4. M.E. Project (pics, lots of pics)
    By skmetal7 in forum Community Club House
    Last Post: 01-08-2007, 10:30 AM
  5. Some Pics of my "mostly" homemade dust extractor.
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 03-27-2005, 01:51 AM
